Hi Eli.
bitaddress.org may not be your best option. This link may have the information you are searching for.
Hi Eli.
Actually, if you’re a noob then bitaddress is a good option imo… simpler the better while you’re getting used to how blockchains work. I used bitaddress for my offline wallets.
It really is much easier than you think.
When you create a key pairing at bitaddress that’s it… lol, see I told you it was easy ;). You just send your maids to the public address and note down very safely and probably in triplicate your secret key. You store maids just like btc. Once you have sent your maids from polo to this new address you can go to omni lookup to see your wallet/address and reassure yourself your coins are where they are supposed to be. When you want to send your coins somewhere you just go to your omni wallet, go to import address and stick your private key in there (no need for your address, it will know which coins are yours from the key alone, clever stuff ;)). Once imported your coins are now accessible in your omni wallet and you can send them back to polo or wherever and the rest to a new offline wallet to be stored again in the same way.
FWIW I would not leave any money on coinbase myself. I do not trust them, insured by lloyds of london or not ;). The great advantage of crypto is empowering yourself. I suggest you always control your own private keys where you can, so send your btc to an offline wallet in the same way, rather than leaving on coinbase for storage. Just one guys opinion ofc. Anything centralised is vulnerable, better to be master of your own fate than relying on others not messing up… an expensive lesson to learn the hard way.
Is there a more secure way to acquire a paper wallet? Another person
commented but it almost sounds like an online wallet…not too sure about
that route. Also wanted to thank you for taking the time to inform me the
way you did…it was very helpful!
Big lover of the project! Have been lurking for a few months.
So I’ve been accumulating a few bitcoins here and there.
I can see them on omniwallet by entering the bitcoin address that hold the tokens.
When I’m ready to sell, is there a way to send them without having to trust anyone? I’m a bit worried about the whole omniwallet concept.
I see that the service needs the private keys sent to their server in order to send the tokens wherever I want to “Private keys are never sent to the server except in an encrypted form”.
I don’t know they won’t send them elsewhere in a few months, after I have kept accumulating and decide to transfer them somewhere.
Is there a trust-less alternative?
Thanks.
Welcome to the forum! The only real way to move the maidsafe coins is ommniwallet by importing your private key. If where you are holding your coins is offline and secure (paper wallet) then you can wait till official network launch (not yet!) and trade your MAID for Safecoin 1:1 by importing your private key then. Hope this helps  just wrote on another similar thread to feel free to search the forum as there are many useful threads pertaining to this topic
After acquiring a paper wallet from bitaddress.org, the public key, if I have bitcoin or ether, would I send these coin to that same public key? Would I use the same private key? Or should I generate new wallets for each coin? Also, is bitaddress.org a trusted place to generate paper wallet addresses? Is there a more secure way to generate a wallet? If so, please leave your suggestion in detail. Thank you so very much!
Welcome  Bitaddress.org is good. Create paper wallets and immediately write down and or print your private key multiple times and store those in a safe place. Create a different address for each different coin type just for your own self organization and sanity! Send your coins to each corresponding address. It’s recommended to disconnect your internet after bitaddress.org has loaded and then generate the address (offline). I hope this helps, also feel free to search the forum for long threads on such discussions.
So, can i just create a btc wallet using Bitaddress.org and send my maidsafe to this address from Poloneix directly?
Yes you can, but create a secure online back of that file/image. With secure online I mean an email drive with 2FA.
After your upload overwrite the file on your hard drive and delete it. You can also save the bitcoin address and send Maidsafecoin to it in the future, that way you don’t have to constantly expose the file.
And welcome to the forum @eli19maz83 @Narain_prakash
After creating a wallet using bitcoin.org, once i send my maidsafe coins from Poloniex, how do i check the balance of the wallet?
How about using a hardware wallet? Would the Ledger Nano S be compatible with Maidsafe coins (it is able to store BTC)?
goto http://omnichest.info/addresssearch.aspx and put in your BTC pub address and should see maidsafe balance
Hi folks - I spent ages today trying to follow the advice on this page. I created a paper bitcoin wallet in the hope of transferring some maidsafe coin that has been sitting at the bitcoin address I used to buy them way back at the crowdsale,
The key issue for me is I access the bitcoin address where the maidsafe is, using multibit classic, what I can’t understand is how to move the maidsafe tokens from this address to anywhere else. I know they are there I can see them by using omnichest to view the bitcoin address; I just need some help getting them out of where they are.
Hope some patient person can set me in the right direction?
Do you have the private key? Import with the private key using omniwallet. You can then transfer as you please.  Add 50 cents worth of BTC to the address to be able to send (transaction fee).
Sign into omniwallet, go to addresses, add address,  import with private key and you are all set.
Thanks Savage - I was making the mistake of trying to import a wallet rather than importing the bitcoin address into my existing omniwallet account.
So I was able to access the bitcoin address by using the private key on omniwallet as you and others have advised - but - I couldn’t then send any maidsafe to another address using omniwallet due to recurring “server error” popping up in a red bar every time it tried to complete the transaction.
I tried switching from firefox to chrome as I heard that this can help - but to no avail (also tried logout / log back in).
Have you / anyone else reading encountered and overcome this “server error” issue?
Thanks again!
To be honest I don’t move coins around much so my experience is limited. I have not encountered the error you mention. @anon40790172 helps folk sometimes perhaps he knows about that.
I had that same problem before. Waited for a few hours then it worked.
Why or how is it possible to determine that a wallet address on the blockchain was incorrectly entered by something as simple as a single lowercase instead of uppercase.
As an example, I entered some watch only paper wallets into Omni and with a couple of them I got only one lower case incorrect so they were not accepted.
How can it tell that the hash is incorrect.
boggles my mind.
The public bitcoin address, (basically one maidsafecoin transaction is a bitcoin transaction) have a Base58Check. Wallets must validate the checksum on an address before send it.
So, much anxiety was spent/wasted on “what if I entered the address incorrectly and my funds cannot be retrieved” for no reason at all.
Getting it wrong is harder than a simple missed keystroke. I’m sure that I’m not the I only person who triple checked then dbl checked again in fear that it would be sent into oblivion never to be retrieved again.
