I appreciate your sharing your perspective, @Mightyfool. I also appreciate how collaborative you were during those times. I am glad that—despite the challenges and obstacles—we were able to accomplish a number of goals that helped to keep this project alive. I hope one day (sooner rather than later) we’ll see this project achieve the impact we believe(d) it could and should have.
Thanks mate. But what exactly Am I looking for here? How do I search? Cheers
That is an explorer for the arb chain.
Putting in an arb address should show you all the movements of coins to or from rhat address.
Edit.
So you could enter the address you thought had maid.
See if that address did have / still has maid.
Or sent maid to another address.
I think I’ve searched correctly here? They were definately there a few weeks ago, so if nobody has stolen them, I have no idea where they are.
Could you have screwed up when saving it? No transactions says to me that they were never there.
“Transactions” tab is for ETH only.
Switch to “Token Transfers (ERC-20)” for ANT tokens. Transactions can’t disappear. When crypto is stolen there just appear to be new outgoing transactions.
Daily volume seems higher than normal days, around $600k, anoyone knows why?
Chart minipulation by a market maker most likely. What looks like a better bottom? One with no volume or one with high volume? If you want to change the trend, you usually do it with a lot of volume. Then, on the retest, people tend to believe the low is in and push for a higher low.
Where did you see the number $600K ?
But there would have been some ETH at some point to transfer the tokens out if they were in there. ??
Other than that I count ox/39 characters instead of ox/40 but maybe I counted wrong. Looks like a invalid address to me.
@Freedom where did you get the tokens from?
You guys mention maid in discussion above which it can’t be anyway, do you expect to see emaid or ant?
Yes but if they were transfered out. I mean for example I don’t transfer ANTs out of my wallet where my nodes earn. So it’s a year old wallet still with empty ETH tab. I don’t know how Freedom got his coins.
I’ve checked all chains for this address but it’s absolutely empty.
@Freedom did you connect Ledger hardware wallet to your metamask? If you did it correctly as per instructions you would eventually have two wallets where one is not used for anything and really stays empty. You could wrongly copy that wallet address generated by metamask instead of your real “working” address which is generated by Ledger itself.
No mate, I haven’t connected ledger hardware to my metamask. How is this done please? Ive just tried and got very confused.
@Obelius @anon26713768 please see response above guys. I can;t even sent a message propoerly, thats how shit I am with technology.
Hey @Freedom I am stumped. I looked the address up too. It has no history.
The tokens were never there.
Thnaks Josh. As the team send me the ANT (after the burn), you reckon they could shed any more light on it?
Im not sure, I have not done a burn myself. If you are lucky they may have record of addresses that burned.
Not sure sorry. Worth a try? @rusty.spork ?
They were definately ant you got of the team and not emaid?
