Posting blow by blow instructions because I did not find them here.
For those who have their coins in their blockchain.info wallet and want to move them to their wallet at OmniWallet.org
Obviously you need to be able to open your blockchain.info wallet. If you cannot, then none of this applies.
While Blockchain.info wallet is open Click on "Setting"s (on left column)
Click on “Addresses”
Find the address that your coins are attached to.
(I only had one, so this was not a challenge. If you have multiple addresses, While in your personal blockchain.info wallet: Copy each of the bitcoin addresses one at a time,and go to Omniwallet.org and insert each address in the “check balances” window. Check each address until you find the one that shows your maidsafe attached. It will show your Maidsafe balance when you insert the correct bitcoin address.)
To the right of your correct bitcoin address: click on “More Options”
From the drop down:menu choose “Private Key”
skip the warning and
Copy your private key.
Now go to bitaddress.org and click on “Wallet Details”
WARNING! You are about to enter your private key on an online service. If you have a good deal of money attached, I was told that you might want to do this offline. At the bottom of the bitadress.org page is a ZIP file. You can download that and apparently, this gives you the ability to convert your private key while offline.I did not do this, but understand it is possible)
Insert your private key, and scroll down to the first WIF address option (51). It will show a QR code and beneath that a long string of 51 numbers and letters. Copy this address.
(close the bitaddress.org window immediately as a safety precaution.)
Then log in to your Omni Wallet
Click on “Add Address”
Chose “add from private key”
Insert your 51 character WIF private key and click next. And viola. You should now see the your bitcoin address with your attached Maidsafe coins.
You are welcome! Took me two days, and a good 6 hours to figure this out.
