For node machines with multiple NICs, passing --node-ip to antctl add is helpful to direct node traffic over the intended interface/IP address. Once added, however, I’m not aware of a way to update the configured IP address for nodes. Is it possible? If not, it would be great to be able to pass --node-interface to antctl add, with the expected behavior that upon each start of nodes, they obtain the current IP address of the interface.
