I am using ant-node-manager to start the node. But seems the —no-upnp not passing to start the node. How to fix it?
Can you post the output of antctl --version
I’m on version:-
Autonomi Node Manager v0.13.0
Package version: 2025.5.1.2
and this command worked for me:-
antctl add --metrics-port 13001-13050 --no-upnp --node-port 12001-12050 --count 50 --rewards-address <redacted> evm-arbitrum-one
and I don’t think I’ve done an update of antctl since.
Note that I put --no-upnp near the start of the line. I had problems putting it further in. I think it has to go before the node ports are specified.
I downloaded from GitHub latest release and run with —no-upnp, and checked with systemctl status antnode1.service , all failed and exec without —no-upnp unlike previous version.
look through the help antctl --help and see if its still there. If not then they seem to either have removed it or maybe it has changed, maybe to --upnp
Just a thought
I have tried to start 300 nodes, just few ten nodes started with the —no-upnp that works well, but others just failed and those started without the —no-upnp and error exit saying upnp gateway.
I shouldn’t update the nodes to 0.4.0, all started failed just like that. Just few nodes started ok since with the flags. And all the failed are started without the flags ![]()
Same issue happening to my network and vps, all started failed with the latest version. Reset and start again still the same…
I have tried forced version to 0.3.11, 0.3.10, after latest upgrade, all with the same issue. The latest antnode crashed something ![]()
I have own build version for RISCV that works fine both node and node manager
But all those release from officials for ARM, aarch64 not working properly. I am not sure what have changed on their side, not debugable, just behaviour.
Now more than 4500nodes down. Thanks for the official upgrade!
I build my own version of ant-node and ant-node-manager, seems fixed the issue. Thanks for your reply.
