I wonder if there is a business angle around home power generation and running nodes too?
Assuming network participation doesn’t burden the routers (once antnode is fully refined), it could be an interesting way to make surplus energy pay.
There have been discussions on this many times for blockchains, but making that profitable with commodity hardware is hard these days. Gone are the days of small, home, miners for the big coins. For antnodes, maybe the numbers will work better though?
If we could use tiny refurbished devices with a basic linux build on them, they could be powered during periods of surplus only (by default), i.e. windy/sunny depending on generation. These devices could be sub £100 or less. Maybe sub £50 if right sized.
These devices could then monotise that excess power and help to support the network. As long as the return exceeds export rates and remains cheaper than battery storage, there should be an economic benefit.
Forming local partnerships with renewable energy installers could be a first step. Given their size, they may accept the risk, especially if there is no cost. They could take a cut of the earnings too, potentially. Indeed it could be a joint incentive between the owner, the installer and the antnode builder.
It would be good to understand the revenue per node of a well connected device could be. Given unmetered internet, combined with free generated energy, the profit margin should be high. If revenue is sufficient, it will pay back the capital cost of the device, then provide an ongoing profit share between the participants.
If we started a movement like this globally, it would be a massive foundational support for the network. It would also give incentives for these power generators to use the network (and its tokens) too.
Longer term, getting deals with bigger generators may be feasible, including the likes of wind/solar farms that get paid to disconnect when the grids hit capacity. Indeed, they could still run nodes while shutting down the grid connections. Off shore could even use satellite internet. Likely powerful, non-commodity, hardware for antnodes too! ![]()
Starting small and buidling up, forming local partnerships, etc, could be a real nice way to start though.
Edit: moving to dedicated topic
Inspired by this thread: Best Safe Node hardware - #1004 by Traktion
