A dummies guide to starting a node
It was all working fine until yesterday. I don’t think I’m using an old version. How to check?
If you run it from git hub it’s always the fresh one I’ll try and check the peers later on and update it and I’ll let you know
Thank you, I appreciate it!
give it a go now :slight_smile:
BAM! All good again! Thanks! :smiley:
@scottefc86 @S4v1nG and anyone else using that start up script from the community git hub.
Next time you start nodes it will also install a script that will stop and start nodes depending on your 15 min load average for the system.
It’s supposed to help stop meltdowns and if your system goes into melt down it will kill all the nodes reset everything and restart the system ready for a fresh start.
You’re the best! Do you recommend to restart all my nodes?
It’s still a bit experimental if you aren’t having CPU issues then no need.
Hi @aatonnomicc, I’ve tried to setup some new nodes, but I don’t think the script is still working.
Can you please check? :slight_smile:
my bad should be fixed now was a copy paste error nodes started with the script will now have open metrics enabled on a port 1000 higher than the nodes working port if you use the port forwarding option.
plan is to try and do something with the dashboard and the open metrics :slight_smile:
As always super quick. Thanks again!
