18:45 emission gone?
Well, there’s a chance those who figured out how to update the node without it being fully restarted may be getting a bigger share of rewards, which could mean the 4m nodes figure is still quite accurate.
Can anyone who used that method to upgrade nodes confirm whether that is the case, or did thise nodes’ rewards also drop off in-line with what others are seeing?
I upgrade with out full reset of the node iv seen rewards decrease inline with what was expected.
Glad to hear that :laughing:
It does mean that unless someone has a way of gaming it, it does seem there are more nodes than 4m or so.
Last time I checked what @Mightyfool stated he was getting with his node count against what I am getting with my node count and both figures matched at earnings per node. And indicated a network size of around 5 million nodes.
Last 7 days network size from NTracking
Not quite right, it is the size of nodes running on version 0.3.8 or 0.3.9
There can be other nodes on earlier versions
I updated with antctl and I get the same amount as with new nodes. Total 40 tokens in 24 hours with 10k nodes.
Check out the Dev Forum
Good point glad you are here to keep me right :slight_smile:
Only the 2 most recent versions earn lollipops right? Or are meant to.
They are according to the announcement in discord. I gather it was just the initial implementation that was for the one version because of the large important change it was
That’s mean still many of us underpaid, like just 20% of the expected
It seems like the emissions per node are still varied. Thats still 3-4x more than I’m receiving.
My restart script does stop all nodes, then slowly relaunches them over several hours, which could be impacting. Originally, it was to ease the load on the network, but maybe it actually punishes the nodes now? :thinking:
Maybe I need to restart each node one at a time, on the same schedule.
Hmm, I restarted nodes on 2 or 3 of my boxes last night, in case it made a difference, and my 24h reward has jumped to 5 ANT. I dunno what to make of that. It seems more inline with yours again @Dimitar .
Could be the others just getting ‘older’ or maybe the new nodes are better positioned? Seems a little hard to fathom.
The truth is out there.
I want to believe.
Is this consistent? 40 every day? mine is far from consistent.
For instance on 13500 nodes, the last 3 days 30, 40, 20 for an average over 3 days of 0.0066 per node.
If yours is consistent I have some investigating to do.
Yes, it varies between 38 and 40 for me.
You had me doing me maths again for my nodes. I am getting around the 0.0025 - 0.0035 per node. And you said 0.0066
But 30 / 13500 is 0.0022 and that is much closer to my experience. My nodes have a fair amount of variance too
very early still for me, not even going to check my math I trust you enough to know that mine was wrong :laughing:
but i did anyway, I did not divide it by 3
That 0.0066 was average for the full 3 days, not per day
Are you as consistent as Dim on a daily basis? I can’t think of any reason why mine is so all over the place and his is not.
Still not right, more figures pointed total nodes > 10M rather than 5M. Just @Dimitar figures more near 5M nodes.
What I got around 0.0018 per node
