Can be useful for mesh networks.
I donât know if this is very useful for mesh networks, IoT very much so, but the technique relies on bouncing waves generated at generators that are plugged into an outlet. If you go away from these generators, youâre not going to be able to use this technique. Theyâre saying the range would be around 30.5 meters, which doesnât really sound like that large a radius especially considering itâs not mobile.
I love it when people post about IoT stuff and say how that would (finally) enable mesh networks.
Last year someone here posted how an IoT device with absolutely pathetic bandwidth would be great for SAFE. But⌠but⌠it runs Linux.
@Onaka, thanks for pointing this out.
To be fair, you donât need the internet to be fast to be useful. For instance, the amazon delivery drones of the future donât need to send my future smart home 8K youtube vids, they only need to send it a private key that takes up less than 10kbs so the home knows the drone is one of the good guys. Of course, none of this is to say that youâd use safenet for close range IOT, as thatâs clearly a terrible idea.
What would happen if you used this technique with those cylindrical antennas, and dishes, for creating relays? Would itâs range still be very limited?
It wouldnât really work, by that point youâre better off just using traditional long range wi-fi. Since youâll be spending the energy to generate the âcarrierâ signal for this technique, you might as well put that power towards a traditional wi-fi transmitter. The best you could do is place the âcarrierâ signal generating device far away and direct its output to a directional antenna that would give a device using this technique the ability to work further away from the generator. But it would not be able to communicate with devices that are at the generator, as the range around the device would still be limited to the 30 meters. Only now the deviceâs location would be even more limited than before.
In short: You wouldnât gain any advantages by doing what you suggest.
