What happens to my emaid coins?
I’m confused about something. What happens to my emaid after the TGE? Will my emaid coins continue to trade on my exchange? Or do they turn into a different coin or token? I’m hoping to keep my emaid as a long term investment.
Eric
You will be able to swap them into ANT. The process will soon be revealed.
Thanks for clarifying. So does ANT have any value other than for buying storage? Can it be converted to ETH or some such?
Value of ANT will be based on market supply and demand. For example ANT will have store of value as the network represents valuable data, some say data is the new gold.
Yes you will be able so swap ant for eth using uniswap.
