In the first post, I wrote that I was installing on Windows
I followed the instructions posted here:
That is, in step 2 according to Install from crates.io I selected: 2c. Windows install vdash.So, following the instructions, I installed the Microsoft Visual C++ redistributors for Visual Studio
then in the instructions it says: Finally to install vdash
Install Rust via https://doc.rust-lang.org/cargo/getting-started/installation.html
That’s right I have Windows x64, and the installation file I installed was rustup-init.exe, and after the installation a message appeared in the terminal:
Rust Visual C++ prerequisites
Rust requires a linker and Windows API libraries but they don't seem to be
available.
These components can be acquired through a Visual Studio installer.
1) Quick install via the Visual Studio Community installer
(free for individuals, academic uses, and open source).
2) Manually install the prerequisites
(for enterprise and advanced users).
3) Don't install the prerequisites
(if you're targeting the GNU ABI).
Should I reinstall it?
When I select 1 it installs again the Microsoft Visual C++ redistributors for Visual Studio only that now only Windows 11 SDK is indicated, and earlier I also selected Windows 10 SDK< because I use Windows 10 Pro.
When I clicked yes in response to the question Continue? (y/N) the following message appeared:
Welcome to Rust!
This will download and install the official compiler for the Rust
programming language, and its package manager, Cargo.
Rustup metadata and toolchains will be installed into the Rustup
home directory, located at:
C:\Users\gggg\.rustup
This can be modified with the RUSTUP_HOME environment variable.
The Cargo home directory is located at:
C:\Users\gggg\.cargo
This can be modified with the CARGO_HOME environment variable.
The cargo, rustc, rustup and other commands will be added to
Cargo's bin directory, located at:
C:\Users\gggg\.cargo\bin
This path will then be added to your PATH environment variable by
modifying the HKEY_CURRENT_USER/Environment/PATH registry key.
You can uninstall at any time with rustup self uninstall and
these changes will be reverted.
Current installation options:
default host triple: x86_64-pc-windows-msvc
default toolchain: stable (default)
profile: default
modify PATH variable: yes
1) Proceed with standard installation (default - just press enter)
2) Customize installation
3) Cancel installation
I understand this is frustrating. None of us have seen that so it’s hard to know what’s wrong or what else to suggest.
Normally if I experience something like this it’s because I didn’t do what I thought I’d done, so I go back and redo every step with extra care.
Other than that I don’t have any useful suggestions other than searching the web for this situation. Have you done that? That’s usually my first step. I generally don’t ask for help until I’ve exhausted at least the obvious things I can do myself.
When I selected 1 the Visual Studio installer turns on, once installed, I additionally installed the Microsoft C++ build tools for Visual Studio 2013 or
later. I had previously successfully installed Rust via Installation - The Cargo Book
After installing the compilation tool and after restarting the computer, I typed the command into the CLI: cargo install vdash however, an error appears:
PS C:\Users\gggg> cargo install vdash
Updating crates.io index
Installing vdash v0.17.9
Locking 271 packages to latest compatible versions
Adding addr2line v0.22.0 (latest: v0.23.0)
Adding ahash v0.7.8 (latest: v0.8.11)
Adding base64 v0.21.7 (latest: v0.22.1)
Adding bitflags v1.3.2 (latest: v2.6.0)
Adding bytecheck v0.6.12 (latest: v0.7.0)
Adding bytecheck_derive v0.6.12 (latest: v0.7.0)
Adding clap v2.34.0 (latest: v4.5.9)
Adding gimli v0.29.0 (latest: v0.30.0)
Adding h2 v0.3.26 (latest: v0.4.5)
Adding hashbrown v0.12.3 (latest: v0.14.5)
Adding heck v0.3.3 (latest: v0.5.0)
Adding heck v0.4.1 (latest: v0.5.0)
Adding hermit-abi v0.1.19 (latest: v0.4.0)
Adding hermit-abi v0.3.9 (latest: v0.4.0)
Adding http v0.2.12 (latest: v1.1.0)
Adding http-body v0.4.6 (latest: v1.0.1)
Adding hyper v0.14.30 (latest: v1.4.1)
Adding hyper-rustls v0.24.2 (latest: v0.27.2)
Adding idna v0.5.0 (latest: v1.0.2)
Adding indexmap v1.9.3 (latest: v2.2.6)
Adding inotify v0.9.6 (latest: v0.10.2)
Adding itertools v0.12.1 (latest: v0.13.0)
Adding linux-raw-sys v0.4.14 (latest: v0.6.4)
Adding mio v0.8.11 (latest: v1.0.0)
Adding notify v5.2.0 (latest: v6.1.1)
Adding ptr_meta v0.1.4 (latest: v0.2.0)
Adding ptr_meta_derive v0.1.4 (latest: v0.2.0)
Adding radium v0.7.0 (latest: v1.1.0)
Adding ratatui v0.25.0 (latest: v0.27.0)
Adding redox_syscall v0.4.1 (latest: v0.5.2)
Adding reqwest v0.11.27 (latest: v0.12.5)
Adding rustls v0.21.12 (latest: v0.23.11)
Adding rustls-pemfile v1.0.4 (latest: v2.1.2)
Adding rustls-webpki v0.101.7 (latest: v0.102.5)
Adding stability v0.1.1 (latest: v0.2.1)
Adding strsim v0.8.0 (latest: v0.11.1)
Adding strum v0.25.0 (latest: v0.26.3)
Adding strum_macros v0.25.3 (latest: v0.26.4)
Adding syn v1.0.109 (latest: v2.0.71)
Adding sync_wrapper v0.1.2 (latest: v1.0.1)
Adding system-configuration v0.5.1 (latest: v0.6.0)
Adding system-configuration-sys v0.5.0 (latest: v0.6.0)
Adding textwrap v0.11.0 (latest: v0.16.1)
Adding tokio-rustls v0.24.1 (latest: v0.26.0)
Adding toml_edit v0.21.1 (latest: v0.22.15)
Adding wasi v0.11.0+wasi-snapshot-preview1 (latest: v0.13.1+wasi-0.2.0)
Adding webpki-roots v0.25.4 (latest: v0.26.3)
Adding windows-core v0.52.0 (latest: v0.58.0)
Adding windows-sys v0.45.0 (latest: v0.52.0)
Adding windows-sys v0.48.0 (latest: v0.52.0)
Adding windows-targets v0.42.2 (latest: v0.52.6)
Adding windows-targets v0.48.5 (latest: v0.52.6)
Adding windows_aarch64_gnullvm v0.42.2 (latest: v0.52.6)
Adding windows_aarch64_gnullvm v0.48.5 (latest: v0.52.6)
Adding windows_aarch64_msvc v0.42.2 (latest: v0.52.6)
Adding windows_aarch64_msvc v0.48.5 (latest: v0.52.6)
Adding windows_i686_gnu v0.42.2 (latest: v0.52.6)
Adding windows_i686_gnu v0.48.5 (latest: v0.52.6)
Adding windows_i686_msvc v0.42.2 (latest: v0.52.6)
Adding windows_i686_msvc v0.48.5 (latest: v0.52.6)
Adding windows_x86_64_gnu v0.42.2 (latest: v0.52.6)
Adding windows_x86_64_gnu v0.48.5 (latest: v0.52.6)
Adding windows_x86_64_gnullvm v0.42.2 (latest: v0.52.6)
Adding windows_x86_64_gnullvm v0.48.5 (latest: v0.52.6)
Adding windows_x86_64_msvc v0.42.2 (latest: v0.52.6)
Adding windows_x86_64_msvc v0.48.5 (latest: v0.52.6)
Adding winnow v0.5.40 (latest: v0.6.13)
Adding winreg v0.50.0 (latest: v0.52.0)
Adding wyz v0.5.1 (latest: v0.6.1)
Compiling proc-macro2 v1.0.86
Compiling unicode-ident v1.0.12
Compiling windows_x86_64_msvc v0.52.6
Compiling cfg-if v1.0.0
Compiling autocfg v1.3.0
Compiling version_check v0.9.4
error: linker `link.exe` not found
= note: program not found
note: the msvc targets depend on the msvc linker but `link.exe` was not found
note: please ensure that Visual Studio 2017 or later, or Build Tools for Visual Studio were installed with the Visual C++ option.
note: VS Code is a different product, and is not sufficient.
error: could not compile `windows_x86_64_msvc` (build script) due to 1 previous error
warning: build failed, waiting for other jobs to finish...
error: could not compile `proc-macro2` (build script) due to 1 previous error
error: failed to compile `vdash v0.17.9`, intermediate artifacts can be found at `C:\Users\gggg\AppData\Local\Temp\cargo-installJMSjJs`.
To reuse those artifacts with a future compilation, set the environment variable `CARGO_TARGET_DIR` to that path.
It looks like Visual Studio or the Microsoft C++ compiler tool is not installed, and in both cases it was installed successfully. What to do about it?
