Using the SAFE network without money
Without my model, or something similar, the network will not even get bootstrapped. If ALL data storage costs safecoins, and farmers only earn safecoins for storing data, then that means a Catch 22 situation from the start.
Oh I“m sure you would, but how much would you provide on a daily basis?
I don“t see why that“s important. This simply means that the more free storage is used, the less everyone earns (see post of @Seneca below). In comparison to the current model where the value of Safecoin tends to an equilibrium between real farming costs and real storage cost the free plan would continuously challenge any storage cost while farming cost remain stable, leading farmers to jump aboard.
Whatever, I think this has explained to you several times. If you donĀ“t want to ā€œbelieveā€ it, only empirical proof helps…
Same amount, but due to inflation not the same in value.
That’s completely false. I wrote that farmers are rewarded the same amount of safecoins for free data storage as for pay-for data storage.
Gosh…do you read posts till the end before you answer? The amount is IRRELEVANT. What matters is VALUE.
I wonder why none has started a World Central Bank yet that implements a new currency and that pays every human’s bills on the planet with the new currency. The adoption would be immense, everyone on earth would use that currency and it’s value would skyrocket!
The value of safecoin will be determined by exchange markets. I think the amount farmers earn will be larger with my model in actual value (USD, EUR etc). Because the SAFE network will be used more, become more popular, have a greater network effect which will make the safecoin market cap larger. So the same amount of safecoins and with a higher actual value.
Because bitcoins for example, are not just handed out to people. Bitcoins have to be mined. And safecoins have to be farmed. So there is a real backing of cryptocurrencies like that.
I leave this excellent point (that was ironic btw) for @happybeing to comment. I“m out.
I have pointed out that the safecoin market cap will be larger with my model. Market cap = total value.
The people to receive the World Central Bank currency also have to sell something first. So it’s ā€œbackedā€ by real resources as well.
So people would have to sell stuff to get for example dollars and then exchange the dollars for the new World Central Bank currency?
Killing a discussion is never the only response, and it is not your call to make. If you can’t engage with a discussion without trying to kill it, you can ignore it. If you believe it should be stopped, you can flag it and explain why. It is not for you to determine whether a discussion deserves to continue or not, and if you think my like is inappropriate, you can raise that in the same way.
Returning to my moderation comment, if you don’t wish to follow forum guidelines you need to lobby for them to be changed, until then it is necessary for you to respect them while posting on the forum, whatever your opinion of posts from others.
