Is anybody else able to build projects on OSX or do you know of a workaround? I would love to hear it. I could simply manually apply the patch, but that’s not exactly distributable.
@joshuef@Shankar Pinging you two for OSX.
Our last successful build and release of example apps was on 21 Dec 2017. Have been you able to successfully rebuild all modules, including node-ffi, on OSX, since then?
Electron doesn’t seem to support v9.x.x yet. Their latest beta version release states that they have updated to v8.9 . The headers that it downloads for rebuilding using node-gyp won’t be available for the incompatible node versions. Initially, I used to face this issue and then made it a practice to check for the supported nodejs version based on the electron version that I was using.
