Hey @Maidsafe,
I’m having trouble creating my own Safe Network. I used Digital Ocean to create a server in the cloud and this server is currently running with 3 nodes, one with --first and two regular nodes. When I try to connect my local node to it however, it gives me an error.
Here is what the error gives me:
cargo run --release -- ##.##.176.134
Running `target/release/maidsafe_vault ##.##.176.134`
Could not decode ##.##.176.134 as valid IPv4 or IPv6 address.
An unknown error occurred
To learn more, run the command again with --verbose.
Note: I just replaced the first two number goups with ##, they are actually numbers and are within the IPv4 range.
