@4M8B is your profile picture the tomato farmed on safenet? oO
Yeah everything is running smooth on Ubuntu14.04 64bit. This time around windows 7 64bit, seems to be a no go.
Hmmmmm same problem with Ubuntu16.04 LTS 64bit
I’m running Mint 17.3 and had no problem logging in this morning. My vault had been running for quite some time however, so maybe the issue is with the vault that has been started recently?
I only downloaded the SAFE launcher on Ubuntu16.04 LTS 64bit and tried to connect and get “Waiting for establishing connection with safenetwork”. It’s probably something else, but what?
i had the same problem with testnet 3
Really not… it’s just a simple step from something I used to scan top 1 million websites.
I think it’s simpler and likely faster, to grep for ‘sample-template-ctx’ and ‘This page is created and published on the SAFE Network using the MaidSafe demo app’.
Still, it’s interesting to know that NCD exists and indeed it might become useful where volume of pages becomes an issue… refreshing all detail for pages that have only minors changes, would likely be helped by using something like that… focusing on the ones that are new or have had substantial content updated. ![]()
Daft question but are we sure that they did work?.. I didn’t see them this test to be sure but it appears like the fail was early on.
I tested the site as soon as I uploaded it. Yes the pics DID load. Now they won’t. So I’m wondering what happened.
@riddim Yeah I change it regulary and the tomato was the inspiration of that day… it fits nice in the profile space ![]()
I’m wondering if we are really testing the network enough. Me for example I leave the vault running and I’ve visited some of the websites over the past few days. Is that enough of a test for now? Or is there more we could do? I guess we’re limited a lot by the space that’s given to the vaults so no way to watch long videos, store a lot of files, etc.
Still curious if there is more I could do to make the test more successful?
Ok, appreciate your replies. My takeaway, indexing safenet the conventional way involves much of doing the same for regular WWW-pages.
Unless, I gather, something like this proposition here in the forum get’s implemented in the future?
Inspector Columbo still in his raincoat, is leaving, hand on the doorknob …
One last question, you suggested grep for parts of the template would suffice but doing this on my sample files:
grep -i -l -e sample-template-ctx -e “This page is created and published on the SAFE Network using the MaidSafe demo app” *.html
Yields:
bishop.html
mypage.html
nigel.html
So one Maidsafe template and two suckers (re)using this but not:
bluebird.html
Is what I’m doing correct or what else is applied?
Vault Stats:
Nodes - 446
Downloaded - 36.5 GB
Uploaded - 33.1 GB
Average download speed - 250 kbit/s
Average upload speed - 200 kbit/s
To help test the network I have setup several safe sites to auto reload every 5 minutes.
! Ah, good catch… I’d forgotten, it also looks at h1 if [sed -n -e ‘s/^(…).*/\1/p’] equals ‘hello world’ then it lumps it with bland sites… if h1 is Hello World then the creator is fairly declaring that page is trivial, that there from the first tests having a number of those and I just wanted a quick filter.
Semantic search looks interesting… I don’t immediately see the ‘need’ for creator hash stamping but suppose if that detail is being generated and put to a pool, then stamping it might be useful. Certainly there’s opportunity for computers to understand language now that would lend itself to linking subjects rather than looking to simple match exact phrases… I did a proof of concept a long time ago and so understand the idea is fairly simple and can be fast but then it rapidly become a volume problem; I think Google already does fuzzy matching by spelling and synonyms. It’ll be interesting to see how the next generation of search evolves.
Yes, I’ve wondered this too. When there is more space available perhaps as suggested above, more content will be uploaded. I’ve been putting some data to /private/ just to help increase the load but unsure if that is useful.
Given that the OP suggest this is a destructive test, I wondered if they are doing a controlled collapse and restart of vaults on the droplets, to test the speed the network can adjust to disruption… but I’m also left guessing what is most useful. OP I think suggested uploading a few webpages, so that done… but is the more useful stress we can apply??
http://dir.yvette.safenet => nothings changed aside from just finding http://francis.safenet
Can you suggest how you get those Vault Stats?.. Downloaded/Uploaded + Nodes I wonder suggests a good indicator of how much activity there is.
The vault tells you how many nodes connected and I get the upload and download data from Ububtu’s system monitor.
I’ve been wondering the same. Should i be turning my vault on and off like crazy to stress the network? So far it has proven completely reliable to me, i’ve reached my upload limit and published a couple sites so maybe i’ll start being crazy with it.
If you use nethogs you will get bandwidth per application. It’s pretty decent actually.
Re-downloaded the packages fixed the problem. Thanks ![]()
