Slight update:
I rebuilt the latest CLI from master with the standard timeout of 60secs.
I can confirm the account creation and login processes are much faster and have yet to have a failure on either.
I need to do further testing but it seems a little faster to put a file.
willie@sputnik:~/projects/maidsafe/safe-api/target/release$ time safe files put /tmp/rand.dat
FilesContainer created at: "safe://hnyynyi4t7c9xsgyzk1m9kyssqcqpb3z41h8o79e6jm4sm7ibdeh5d1icabnc"
+ /tmp/rand.dat safe://hbkyyonzb9cqfjji8r8xoa9fcm5obkps59fce6w9ie57kz93s77yz4h4bc
real 0m53.904s
user 0m0.397s
sys 0m0.074s
willie@sputnik:~/projects/maidsafe/safe-api/target/release$ ls -l /tmp/rand.dat
-rw-r--r-- 1 willie willie 1650688 Mar 11 12:02 /tmp/rand.dat
This time round I set the no of 1k blocks to 1612 in my attempt to find the largest file I could put with this laptop.
willie@sputnik:~/projects/maidsafe/safe-api/target/release$ dd if=/dev/urandom of=/tmp/rand.dat bs=1k count=1612
1612+0 records in
1612+0 records out
1650688 bytes (1.7 MB, 1.6 MiB) copied, 0.0153625 s, 107 MB/s
**UPDATE** - we have now released the first [v0.17.0 Alpha Desktop Browser](https://github.com/maidsafe/safe_browser/releases) version which is compatible with Baby Fleming!
Launching your current Alpha Browser will automatically prompt you to update, or you can download the latest Alpha version from [here](https://github.com/maidsafe/safe_browser/releases)
Note that ONLY v0.17.0 (Alpha, Beta and full release) and above is compatible with Baby Fleming. v0.17.0 is NOT compatible with vaults Phase 1, i.e. the current Shared Vault - if you intend to use the Shared Vault then please use [Browser v0.16.0](https://github.com/maidsafe/safe_browser/releases/tag/v0.16.0).
We’ve tested this internally on macOS so far and all appears to be working as expected. Give it a go and let us know if you find any problems!
Note that this new Alpha v 0.17.0 IS NOT compatible with the current single Shared Vault from Vaults Phase 1, this is for use with the single section testnet only, aka Baby Fleming/Vaults Phase 2a.
We did release a full v0.16.0 Browser this morning for use with the Shared Vault - you can find this here if you want to use the Shared Vault.
Performance on a 1.7Mb file is random. Sometimes it works fine, sometimes its slow and on the fourth run it just timed out
1612+0 records in
1612+0 records out
1650688 bytes (1.7 MB, 1.6 MiB) copied, 0.0162145 s, 102 MB/s
FilesContainer created at: "safe://hnyynywrhbb8cajh8u9ir457s7qhi8ygx78fqtrnhyos8icpu4sq8mhe8wbnc"
+ /tmp/rand.dat safe://hbkyyonncsougp7kofmecddj8hjez8pit33u6rx8zweze8atkquqhgcrqe
real 3m28.733s
user 0m0.374s
sys 0m0.070s
FilesContainer created at: "safe://hnyynyixnbtksge58yc4m58w4c5aq14i1bn5une8bfzhqzare47zydqge1bnc"
real 1m23.098s
user 0m0.352s
sys 0m0.076s
FilesContainer created at: "safe://hnyynysu1x3tsuwucqne6iewyxefwyu1qszpp13w3epzty4zddxnrscn5sbnc"
real 0m53.801s
user 0m0.353s
sys 0m0.069s
[2020-03-11T13:21:28Z ERROR safe] safe-cli error: [Error] NetDataError - Failed to PUT Sequenced Append Only Data: Error(CoreError(Request has timed out - CoreError::RequestTimeout))
real 6m42.966s
user 0m0.357s
sys 0m0.096s
willie@sputnik:~/projects/maidsafe/safe-api/target/release$ safe vault killall
Success, all processes instances of safe_vault were stopped!
EDIT: trying again with different test data of the same size
willie@sputnik:~/projects/maidsafe/safe-api/target/release$ for i in 1 2 3 4 5 6; do dd if=/dev/urandom of=/tmp/rand.dat bs=1k count=1612; time safe files put /tmp/rand.dat; done
1612+0 records in
1612+0 records out
1650688 bytes (1.7 MB, 1.6 MiB) copied, 0.0407925 s, 40.5 MB/s
FilesContainer created at: "safe://hnyynyw5791zunygowkspd9jaaa3qwi8p6xjy87ji4amyimke6goykek4ybnc"
+ /tmp/rand.dat safe://hbkyyod4cyns8z8o1nbed9g3qjkt1g6ktei3w7g6xynh7wesee5wq59x9d
real 0m47.529s
user 0m0.361s
sys 0m0.064s
1612+0 records in
1612+0 records out
1650688 bytes (1.7 MB, 1.6 MiB) copied, 0.0147024 s, 112 MB/s
FilesContainer created at: "safe://hnyynyzn1gw1493z1edk6ddf19n7keo9nts8krn3kjms8sqzjj5hzqkojqbnc"
+ /tmp/rand.dat safe://hbkyyodgxipuqo9jgweubdpuzxdxkzupmj5c6ch9xrkxiaicjpuhcct656
real 1m13.752s
user 0m0.347s
sys 0m0.087s
1612+0 records in
1612+0 records out
1650688 bytes (1.7 MB, 1.6 MiB) copied, 0.0173103 s, 95.4 MB/s
FilesContainer created at: "safe://hnyynyzjo5g5enwfjrdseiku3ooj5bezak5iawcqa9idcrs1xdyukjwprnbnc"
+ /tmp/rand.dat safe://hbkyyon58tj9d3ohpp6zom7gscfnmfa3xa4fhf7f1ppcqfxye461okxej3
real 2m11.281s
user 0m0.356s
sys 0m0.096s
1612+0 records in
1612+0 records out
1650688 bytes (1.7 MB, 1.6 MiB) copied, 0.0131708 s, 125 MB/s
FilesContainer created at: "safe://hnyynysdf4onnbpqjyry6khp6s81rp3i9yphsb5rpbps4seqjzzorbchxobnc"
+ /tmp/rand.dat safe://hbkyyon16u6w6ikgpxu566jzibhxig66grf94cmaab8dfo75whxc8wxekq
real 1m41.019s
user 0m0.379s
sys 0m0.091s
1612+0 records in
1612+0 records out
1650688 bytes (1.7 MB, 1.6 MiB) copied, 0.0132232 s, 125 MB/s
FilesContainer created at: "safe://hnyynyi1ixntc4m8msjhpoxnzau6odp6r5eyddt6g66j1k4rkhe34tw3eqbnc"
+ /tmp/rand.dat safe://hbkyyody49dtm574micwscgpkm9h385hxx8bet7eqo53azm698qre5tgi4
real 1m28.365s
user 0m0.350s
sys 0m0.086s
1612+0 records in
1612+0 records out
1650688 bytes (1.7 MB, 1.6 MiB) copied, 0.0130252 s, 127 MB/s
FilesContainer created at: "safe://hnyynyzynctcqyt89ew3fzmfqutrmubewtf4kqjs5uq71qcrab3exauoj1bnc"
+ /tmp/rand.dat safe://hbkyyodcd1rsrgt3st76eko58mapcuyrpeijg6qm6p8djrmsxpn6r6mx55
real 1m2.815s
user 0m0.368s
sys 0m0.063s
so an average of 84 secs to put a 1.7MB file of random data but with considrable variation. Long long time since I did std deviations and stuff but the sample size is (as yet) too small for that to make much sense.
Yes, Browser v0.16.0 and v0.17.0-alpha.0 are both compatible with the CLI v0.9.0 and safe-authd v0.0.5
UPDATE - CLI 0.9.0 and authd 0.0.5 are only compatible with Baby Fleming, and only Browser versions 0.17.0 and above will work with Baby Fleming. If you want to access the Shared Vault then you should use the previous versions of the CLI and authd, along with v0.16.0 of the Browser
Actually @JPL I’ve just been discussing with @bochaco and he believes that CLI v0.9.0 and authd v0.0.5 will not be compatible with the Shared Vault, so through association this means that they therefore can’t be used anywhere that you can access with any Browser version less than v0.17.0. Apologies for any confusion.
PS I just tested & verified that I can’t log into or create an account on the Shared Vault using CLI 0.9.0 and authd v0.0.5
By the way, my Sites history (ie list of sites I uploaded) is still carried over from the shared vaults even with the new browser and baby-fleming. Where is that information stored?
That’s stored in local storage currently that’s why your new browser still finds them, eventually we’ll be able to again store them on the network as part of your account’s data as we used to have it before.
`appData` Per-user application data directory, which by default points to:
* `%APPDATA%` on Windows
* `$XDG_CONFIG_HOME` or `~/.config` on Linux
* `~/Library/Application Support` on macOS
followed by the app name (SAFE Browser in this case)
Guys I understand that the network is currently uploading small files, but it seems kind of sluggish. I assume that is why it is called baby fleming, it cant crawl nor run
I would like to hear from you experts, what your overal idea is on the Baby Fleming after a week of testing.
Am I wasting my time reporting results from one run only?
Should I do a minimum of n test runs with different random data but constant input file size ?
Should I put any more effort into correcting and extending my wee test script? run-new-network.sh
