Test scripts a good as they can be shared. We have most of what we need so far I recon. It’s incredibly valuable and has created a ton of great work for us, really good.
Makes sense if everyone is testing in the same manner.
Reduces the variables to hardware and OS.
Do you have a test script for uploading successively larger files and logging the outcome (and possibly CPU and memory used) or do you do that manually?
EDIT: thinking about it that’s going to be OS-specific.
It 's getting worked on now YOu are one of these Windows persons, yes?
Can I interest you in VirtualBox and a Linux LiveUSB stick?
Yes - I ring a little bell to warn passers-by that I’m unclean
I also use Linux on a stick but I have to use Windows mainly for Excel - unfortunately no open-source alternatives come close.
Aye the VB macros just dont work too well on Libre Office Calc
here is the latest versiion of run-new-network.sh
Expect frequent iterations.
This script will archive any existing Baby Fleming logs and save them to a timestamped directory. It will then create a set of credentials for a test user, create the account and login.
as yet it does not do any actual testing but does give you a reproducible baseline to start with.
Linux only I’m afraid but might, just maybe work on a Mac.
Mrs Southside has served me with an exclusion order on her new Mac tablet from work. I am barred from going within 5 metres of it. So you Mac fanbois are on your own…
I save this file to ~/.safe/vault, make it executable with chmod +x run-new-network.sh and run it from there.
It is strongly recommended to build the latest CLI from master. Quickie instructions for doing this in Linux coming soon.
Quick n dirty instructions to build the latest CLI
first run rustc -V
if your version of rust is < 1.41 then run
rustup install stable
cd to your working directory
then…
git clone https://github.com/maidsafe/safe-api
cd safe-api
cargo build --release
make yourself a coffee…
then…
cd target/release && sudo cp safe /usr/local/bin
I’m quite sure there are more ‘correct’ ways of doing this - but it works ![]()
If anyone wants to help improve the run-new-network.sh script, it is now at
Change nappies? Well as long as it’s just wee as you say
Some stats from my tweaking gossip intervals to understand their impact, seeing how long it takes to upload files of various sizes.
| Baby-fleming | Change A | Change B | |
| Size (kB) | Time (s) | Time (s) | Time (s) |
| 700 | 11.271 | 49.47 | 21.688 |
| 800 | 12.074 | 53.454 | 16.894 |
| 900 | 14.047 | 60.628 | 19.654 |
| 1000 | 14.595 | 57.409 | 19.647 |
| 1100 | 13.292 | 50.306 | 23.107 |
| 1200 | 85.711 | 62.416 | 19.867 |
| 1300 | 23.079 | 67.187 | 24.865 |
| 1400 | 32.758 | 48.352 | 22.146 |
| 1500 | killed for cpu | 74.33 | 26.145 |
| 1600 | 49.884 | 25.31 | |
| 1700 | 46.471 | 27.088 | |
| 1800 | 68.727 | 24.599 | |
| 1900 | 50.433 | 29.201 | |
| 2000 | 46.137 | 30.306 | |
| 2200 | 60.206 | 26.344 | |
| 2400 | 70.675 | 42.646 | |
| 2600 | 57.213 | 62.955 | |
| 2800 | 74.288 | 49.274 | |
| 3000 | 360.143 | 93.373 | |
| 3500 | 63.956 | 66.507 | |
| 4000 | 81.542 | 57.404 | |
| 4500 | 101.312 | killed for cpu | |
| 5000 | 65.263 | ||
| 6000 | 81.199 | ||
| 7000 | 182.018 | ||
| 8000 | 162.767 | ||
| 9000 | 229.971 | ||
| 10000 | killed for ram |
Change A: Gossip slower, instead of 1s updates change to 7s updates
src/parsec.rs:L63 (or use ROUTING_GOSSIP_PERIOD environment variable)
-pub const GOSSIP_PERIOD: Duration = Duration::from_secs(1);
+pub const GOSSIP_PERIOD: Duration = Duration::from_secs(7);
Allowed larger files to complete but was overall slower for all file sizes. Shows that maybe nodes are being flooded by other gossip so can’t make up their mind about their own stuff…?
Change B: Gossip spread out between 1-3s rather than always every 1s, to try to help any lockstep situations that may be happening.
src/parsec.rs:L364
pub fn gossip_period(&self) -> Duration {
- self.gossip_period
+ let t = rand::thread_rng().gen_range(0, 2000);
+ self.gossip_period + Duration::from_millis(t)
Allowed larger files to be uploaded without the performance hit from change a, but files were not as large as change a.
I will have a go at this with a tweak to Change B with a random gossip interval 2-5secs.
Can you share the script you used to run these tests, please? I’m working on one of my own but I suspect yours would be a lot more polished and ‘correct’ than my fumblings with bash.
Even so we seem to be hitting a limit of ~10Mb which does not bode well for storing large media.
How much RAM was in your test box and which processor?
I’m manually running these uploads.
This was on 16GB i7-8565U CPU @ 1.80GHz laptop
You’ll also need to add this near the top of src/parsec.rs for change b
use rand::Rng;
Seems like this is where CRDT comes in?
Hey @mav, seems like you figured it all out by yourself
Just a couple of notes:
- The “routing table size” prints only elders. This is by design because we don’t know how many non-elders there are in any other section except our own. I can see how it can be surprising though, so we should probably change the wording to make it obvious.
- The
MembershipKnowledgemessage is currently sent periodically (every 2 seconds) which isn’t strictly necessary but it was done this way because it was simple to implement and seems to cover all the edge cases. We do plan to change it though, so that it is only sent when something changes like you are suggesting.
See Baby Fleming Update post here
