I am following these steps:
https://github.com/hunterlester/safe_browser/blob/dev-mode/README.md
I have downloaded Node.js 6.5.0, Rust, and git, but when I try to install dependencies, I fail at $ npm i
it says undefined postinstall
Anyone could help ?
I am on windows 10 which @hunterlester said is working
The first error I see is that there is no Python executable.
Download it here: Download Python | Python.org
Choose the 2.7.13 version, not 3.6.1
I think node-gyp is dependent on Python and it doesn’t play well with Python 3.
Thanks for your help !
downloaded python 2.7.13, restarted my machine, and then npm i
got this
What is weird is I had Visual build tool 2015 installed
Oh I see. I’m really glad that you started this thread because I forgot about all the software that I’ve installed on my system.
You need Microsoft Visual Studio.
I think that you don’t need to install the full package with the IDE. You may be able to just download the native build libraries here: Download Visual Studio Tools - Install Free for Windows, Mac, Linux
Scroll to bottom of screen and choose Build Tools for Visual Studio 2017.
Oh wait, sorry I missed what you wrote. You already have Visual studio installed.
Will you paste that error text here so that I can take a closer look at it?
UPDATE:
Ah I see now. You have Visual Studio installed but you don’t have the C++ build tools.
http://landinghub.visualstudio.com/visual-cpp-build-tools
so I have Microsoft Visual Studio 2017 and Microsoft Visual C++ build Tools installed, and have uninstalled all previous versions.
have set up MSVS version using the command:
setx GYP_MSVS_VERSION 2017
I still can’t build.
talking with hunter in pm.
Will let everybody know the fix as soon as we figure it out.
JPL
July 7, 2017, 4:16pm
7
Getting this set up on Windows is like pulling teeth if my experience is anything to go by. There is a thread on the safedev
forum Can anyone build Mock-Routing on Win? - #40 by mav - Support - Safe Dev Forum which is worth a look.
hunterlester:
Thanks for that little insight - that will save me some messing about - I WAS trying to do as much as poss with Python3 but I’ll go back to the old one for this.
system
Closed
September 5, 2017, 1:16pm
9
