Safe browser is not running
I have install Ubuntu freshly then i have dwonload safe browser,But the programm file is not running in my machine.Can anyone help? I am new in Linux.
Hey there @avirup. I’ll be glad to help. Can you please confirm that you have downloaded the latest release of the browser from this link:
What are the steps that you have followed to open browser?
Just double click the safebrowser program file.
I have downloaded it from here
are you seeing any errors there @avirup?
Does the non-dev version of the browser work for you there?
@joshuef
No there are no any errors.
I am using non-dev version should I try dev version??
Now it is opening .
I have installed this package in my ubuntu
sudo apt-get install libgconf-2-4
After then it is opening…
Ah sorry, I thought I read you were using dev somewhere.
Glad you got it working!
Hi,
Glad you figured out the workaround. This is actually a known issue which is on the board to be resolved in a future release. It seems to be particular to Ubuntu rather than other Linux distros.
Calum
