Hi all,
If any one can help:
[root@hp8300 glibc-build]# safe-browser &
[1] 20430
[root@hp8300 glibc-build]# Error: Dynamic Linking Error: /lib64/libc.so.6: version GLIBC_2.18' not found (required by /opt/maidsafe/safe-browser-v0.6.0/resources/app/node_modules/beaker-plugin-safe-authenticator/dist/libsafe_authenticator.so) at new DynamicLibrary (/opt/maidsafe/safe-browser-v0.6.0/resources/app/node_modules/ffi/lib/dynamic_library.js:74:11) at Object.DynamicLibrary (/opt/maidsafe/safe-browser-v0.6.0/resources/app/node_modules/ffi/lib/dynamic_library.js:33:12) at /opt/maidsafe/safe-browser-v0.6.0/resources/app/node_modules/beaker-plugin-safe-authenticator/dist/api.js:193:36 at Promise (<anonymous>) at LibLoader.load (/opt/maidsafe/safe-browser-v0.6.0/resources/app/node_modules/beaker-plugin-safe-authenticator/dist/api.js:187:15) at Object.loadLibrary (/opt/maidsafe/safe-browser-v0.6.0/resources/app/node_modules/beaker-plugin-safe-authenticator/dist/api.js:96:25) at Object.<anonymous> (/opt/maidsafe/safe-browser-v0.6.0/resources/app/node_modules/beaker-plugin-safe-authenticator/index.js:5:19) at Object.<anonymous> (/opt/maidsafe/safe-browser-v0.6.0/resources/app/node_modules/beaker-plugin-safe-authenticator/index.js:20:3) at Module._compile (module.js:571:32) at Object.Module._extensions..js (module.js:580:10) XDG_RUNTIME_DIR (/run/user/1000) is not owned by us (uid 0), but by uid 1000! (This could e g happen if you try to connect to a non-root PulseAudio as a root user, over the native protocol. Don't do that.) [AUTO-UPDATE] Error: Disabled. Only available on macOS and Windows. (node:20430) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): 1: Failed to load native libraries: Error: Dynamic Linking Error: /lib64/libc.so.6: version GLIBC_2.18’ not found (required by /opt/maidsafe/safe-browser-v0.6.0/resources/app/node_modules/@maidsafe/safe-node-app/src/native/libsafe_app.so)
(node:20430) DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
[1]+ Done safe-browser
Sadly did not work:
cd /tmp
wget http://ftp.gnu.org/gnu/glibc/glibc-2.18.tar.gz
tar -xvzf glibc-2.18.tar.gz
cd glibc-2.18/
mkdir glibc-build
cd glibc-build/
…/configure --disable-sanity-checks
make
make install
