Running launcher behind a proxy
I’m trying to open it in a work place , can I set a proxy before connecting ? What is the step by step to join the safe network ?
Hi @macdasi are you using the latest version?
The step by step is here.
Yes , so first step is installing the launcher , run it , create an account (here where I get the message).
I think there is some blocking with the office firewall or something , we do have a proxy, where can I set it ?
@macdasi if you are comfortable creating a GitHub issue can you please create one here and attach the Client.log it should be created in the same place that you are running the binary from - thank you.
Hey @macdasi,
If you’re wondering how to actually set up the proxy for Launcher then there are guides here for all the major OSes.
Sorry if you’ve followed these already! :slight_smile:
I did it, still doesn’t working .
How can i use Safe Netwokr, if i’m using internet connection by the proxy from the http://advanced.name?
