Running Ant-Nodes: Connectivity
Hi everyone,
how do i know that my node is reachable? I’m running my nodes through antctl, doing manual port forwarding and was wondering if everything is set up properly. Is there a “keyword” in the logs, that i can search for? Like incoming connection.
Thank you
See if it hands out any quotes.
That is the reliable way.
IIRC quote will be the key word to look for in the logs
