You did very well with Vdash, you stepped up and did the work, that is amazing.
I am just trying to understand if the nodes are working well and what the cause might be if they are suffering. Hopefully Autonomi team will add some low cpu usage metrics to show if nodes are healthy, earned nanos and such.
To set a path range sounds good, how to do that? Would it look like example
vdash ā$HOME/.local/share/safe/node/safenode1/logs/safenode.logā-ā$HOME/.local/share/safe/node/safenode20/logs/safenode.logā
No, you could just pass individual paths one after the other. bash can do it more effectively but donāt know exactly what that would look like without messing about.
Maybe itās because I have not wiped my old nodes during upgrade. I am seeing a factor of 2x on upstream.
Probably it will be better to start with fresh nodesā¦
I have split my two ISPs, one for home networking, one for autonomi/homelab. Best move ever - I am getting so many compliments now, about how responsive the home network has become.
I have upgraded my router (a dedicated UDM-PRO MAX) with plenty of CPU (50%) and memory, and upgraded my ISP. Unfortunately, doubling ISP bandwidth does not always translate in doubling the number of connections. Now I am probably ISP-limited; a problem with ISPās equipment, the ONT maybe. Thatās as far as I am going to get utilizing my āspare resources.ā
They are reselling generic chinese boxes, you can find it under SZBox, Topdon and other brands. https://www.aliexpress.com/item/1005006026499800.html
You can probably find real manufacturer on Alibaba and have it made with your name/logo on it if you want.
Specifications look good, but noise/heat/thermal throttling on full load you will hate to try, I wasnāt able to find solid review.
Hey so I got my mikrotik rb5009 router setup I just have it on the default settings pretty much just plugged it in put my modem in bridge mode and started 150 nodes but my internet now is a bit bogged down, the cpu on my router is only at 15% and I think I should be able to run like 500 nodes through this router is there any settings I need to mess around with to get this router to handle more nodes?
Can anyone tell me approximately how many nodes I can handle with a router that delivers 30,000 simultaneous connections. I have plenty of everything else like a 1.5 fibre connection, etc. Iām effortlessly running 20 nodes from home now. I would like to run more. Any help is welcome, thanks
You could look into the concept of āDMZ Hostā ⦠a machine placed in this slot gets exposed directly to all incoming trafficā¦and negates the requirement to port forward.
Iām doing this with my lowly 2 core netcomm as a last resort to receive chunks without --home-network, alas I had many peers but zero data.
So I continue with DMZ Host, but with --home-network ā¦this, together with disabling logging gets me 50 nodes (thin client) whilst maintaining stable internet/ Kayo (sports streaming) on a 20Mbs uplink.
End of month I upgrade to a massive 40mbs uplinkā¦so more headroom.
well my connection is cutting in and out. and Iām seeing it on my own pc which is plugged into the router (all my devices are plugged into the router and I have no wifi atm)
My connect speed is slower than normal dl is about 500 mbps (should be 8-900) and my ul is 85mbps (should be over 100)
Following @anon26713768ās suggestion that udp-timeout be changed to 30s to match what nodes do I had a look at this and other settings available.
udp-timeout
The default is 10s which it was still set to. That doesnāt seem like a lot.
udp-stream-timeout
The default is 3 mins which it was still set to. That seems like a lot.
I think that one is potentially the more relevant one for nodes.
So what Iāve done is set both:-
udp-timeout
udp-stream-timeout
to 40s. I donāt want to set them to exactly 30s and a node ever has to establish a connection again for something it was still using. There doesnāt seem to be much penalty to an extra 10 seconds.
Changing udp-timeout from 20s to 40s made no difference at all.
Changing udp-stream-timeout from 3 mins to 40s has made a huge difference to the number of connections open on the router. For running 10 nodes it has gone down from between 8 to 10k to 2 to 3K. There has been no apparent change to the behaviour of nodes and no increase in the error rate.
Just for a laugh I set both udp-timeout and udp-stream-timeout to 1s. The number of connections went down to 1.8k to 2k for the 10 nodes as expected. It seemed that there were more errors but not a huge amount more.
So it looks like connections are established and used for a bit and the router keeps them in the NAT table for an unnecessary amount of time if udp-stream-timeout is higher than 40s so thatās the figure Iāve settled on for both.
I think itās bandwidth rather than number of connections that is holding me back from being able to run more nodes but Iāll be putting that to the test!
I wonder what the setting for udp-stream-timeout is on consumer routers? I wonder if theyād be able to handle more if the setting can be changed?
It could be a highly ironic situation where a consumer grade or carrier supplied router would be able to handle more nodes if the udp-stream-timeout could be reduced so itās not overloaded with keeping unused connections open but it canāt because that setting is not changeable. So you need an over specced router like the MikroTik RB5009 to be able to change the setting. But a router like that can handle the increased number anywayā¦
