Safe network version: 0.52.0 0.47.0 0.40.0
I’m trying to run an app called the safe network inside a rootless podman container and then connect another node to it.
It fails because the host node tells container node that it should reach it on 10.0.2.100:random,
when it should be 192.178.168.29:12001.
The IPs I’ve chosen
Root node inside container
- Local: Tap0 address:12000
- Public/Published: LAN address or public address:12000
Host
- Local: LAN address:12001
- Public: LAN address:12001
host logs
INFO 2021-12-29T11:20:26.259319Z [sn/src/routing/routing_api/mod.rs:L152]:
➤ 6da530.. Bootstrapping a new node.
INFO 2021-12-29T11:20:26.276224Z [sn/src/routing/routing_api/mod.rs:L166]:
➤ 6da530.. Joining as a new node (PID: 202926) our socket: 192.168.178.29:12001, bootstrapper was: 192.168.178.29:12000, network's genesis key: PublicKey(0de4..893d)
INFO 2021-12-29T11:20:26.276595Z [sn/src/routing/core/bootstrap/join.rs:L505]:
➤ join {network_genesis_key=PublicKey(0de4..893d) target_section_key=PublicKey(0de4..893d) recipients=[Peer { name: 6da530(01101101).., addr: 192.168.178.29:12000, connection: Some(Connection { id: 944978480, remote_address: 192.168.178.29:12000, .. }) }]}
➤ send_join_requests {join_request=JoinRequest { section_key: PublicKey(0de4..893d), resource_proof_response: None, aggregated: None } recipients=[Peer { name: 6da530(01101101).., addr: 192.168.178.29:12000, connection: Some(Connection { id: 944978480, remote_address: 192.168.178.29:12000, .. }) }] section_key=PublicKey(0de4..893d) should_backoff=false}
➤ Sending JoinRequest { section_key: PublicKey(0de4..893d), resource_proof_response: None, aggregated: None } to [Peer { name: 6da530(01101101).., addr: 192.168.178.29:12000, connection: Some(Connection { id: 944978480, remote_address: 192.168.178.29:12000, .. }) }]
INFO 2021-12-29T11:20:27.451718Z [sn/src/routing/core/bootstrap/join.rs:L367]:
➤ Setting Node name to 8d1c11.. (age 98)
INFO 2021-12-29T11:20:27.451765Z [sn/src/routing/core/bootstrap/join.rs:L374]:
➤ Newer Join response for us 8d1c11(10001101).., SAP SectionAuthorityProvider { prefix: Prefix(), public_key_set: PublicKeySet { public_key: PublicKey(0de4..893d), threshold: 0 }, elders: {Peer { name: 2d82ba(00101101).., addr: 192.168.178.29:12000, connection: None }} } from Peer { name: 2d82ba(00101101).., addr: 192.168.178.29:12000, connection: Some(Connection { id: 944978480, remote_address: 192.168.178.29:12000, .. }) }
INFO 2021-12-29T11:20:28.011536Z [sn/src/routing/core/bootstrap/join.rs:L505]:
➤ send_join_requests {join_request=JoinRequest { section_key: PublicKey(0de4..893d), resource_proof_response: None, aggregated: None } recipients=[Peer { name: 2d82ba(00101101).., addr: 192.168.178.29:12000, connection: Some(Connection { id: 944978480, remote_address: 192.168.178.29:12000, .. }) }] section_key=PublicKey(0de4..893d) should_backoff=true}
➤ Sending JoinRequest { section_key: PublicKey(0de4..893d), resource_proof_response: None, aggregated: None } to [Peer { name: 2d82ba(00101101).., addr: 192.168.178.29:12000, connection: Some(Connection { id: 944978480, remote_address: 192.168.178.29:12000, .. }) }]
ERROR 2021-12-29T11:21:28.031312Z [sn/src/routing/core/bootstrap/join.rs:L164]:
➤ Node cannot join the network since it is not externally reachable: 10.0.2.100:53100
container logs
INFO 2021-12-29T10:19:25.359368Z [sn/src/routing/routing_api/mod.rs:L85]:
➤ 2d82ba.. Starting a new network as the genesis node (PID: 1).
INFO 2021-12-29T10:19:25.477464Z [sn/src/routing/routing_api/mod.rs:L128]:
➤ 2d82ba.. Genesis node started!. Genesis key PublicKey(0de4..893d), hex: ade4e34061a1b0f3d1e81999bf075c0af6046f02bd81178e186a5d593957ca948dc7682d6ce729aa924aeb1a8d6ef97c
INFO 2021-12-29T10:19:25.477680Z [sn/src/routing/routing_api/dispatcher.rs:L87]:
➤ Starting to probe network
INFO 2021-12-29T10:19:25.477867Z [sn/src/routing/routing_api/dispatcher.rs:L115]:
➤ Writing our PrefixMap to disk
INFO 2021-12-29T10:19:25.477911Z [sn/src/routing/core/mod.rs:L212]:
➤ Writing our latest PrefixMap to disk
INFO 2021-12-29T10:19:25.482805Z [sn/src/node/node_api/mod.rs:L87]:
➤ Node PID: 1, prefix: Prefix(), name: 2d82ba(00101101).., age: 255, connection info: "192.168.178.29:12000"
INFO 2021-12-29T11:21:28.021787Z [sn/src/routing/core/comm.rs:L183]:
➤ Peer 10.0.2.100:53100 is NOT externally reachable: Send(ConnectionLost(TimedOut))
host command
safe networks switch lan-ipv4 && \
RUST_BACKTRACE=full ~/.safe/node/sn_node -vv \
--clear-data \
--skip-auto-port-forwarding \
--local-addr 192.168.178.29:12001 \
--public-addr 192.168.178.29:12001 \
--root-dir=/home/folaht/.safe/node/joinnode-ipv4_12001 \
--log-dir=/home/folaht/.safe/node/joinnode-ipv4_12001 &
The IP address and port the host node tries to connect to
[folaht@Rezosur-zot joinnode-ipv4_12001]$ safe networks
| Networks | | |
| Current | Network name | Connection info |
| * | lan-ipv4 | /home/folaht/.safe/cli/networks/lan-ipv4_node_connection_info.config |
| | local-ipv4 | /home/folaht/.safe/cli/networks/local-ipv4_node_connection_info.config |
| | local-ipv6 | /home/folaht/.safe/cli/networks/local-ipv6_node_connection_info.config |
[folaht@Rezosur-zot joinnode-ipv4_12001]$ cat /home/folaht/.safe/cli/networks/lan-ipv4_node_connection_info.config
["8520343e22464270f10ef2408902ab87b1186e7410cf57d5390c9a44b8953097e0b36e2bd29d1169eaa446a82966b12d",["192.168.178.29:12000"]]
status container node
[folaht@Rezosur-zot rootnode-ipv4]$ podman ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
f4c6a137b93d localhost/rootnode-ipv4_test:latest 37 minutes ago Up 37 minutes ago 192.168.178.29:12000->12000/tcp, 192.168.178.29:12000->12000/udp test_rootnode-ipv4
pid container node
[folaht@Rezosur-zot rootnode-ipv4]$ ps -ef | grep sn_node
10999 51780 51777 0 18:13 ? 00:00:01 sn_node -vv --idle-timeout-msec 5500 --keep-alive-interval-msec 4000 --skip-auto-port-forwarding --clear-data --local-addr 10.0.2.100:12000 --public-addr 192.168.178.29:12000 --log-dir /home/admin/.safe/node/rootnode-ipv4_12000 --root-dir /home/admin/.safe/node/rootnode-ipv4_12000 --first
folaht 52185 4230 0 18:50 pts/1 00:00:00 grep --colour=auto sn_node
