I’m completely stuck at the moment with Ipv4 rootless and Ipv6 rootfull
I’ve raised this issue here and I’ll soon add the issue to podman discussions.
For IPv6 rootfull, the issue is more vague to me, because I’m not even sure if the IP my node is trying to connect with is the correct one.
I notice that [fdc2:9f3e:3d11:40c::1]:12001 is not the same as the local address [fdc2:9f3e:3d11:40c::2]:12001. It’s in fact the gateway address. Is that the address it should connect to?
ps -ef | grep node_dir_1
sn_node -v
--idle-timeout-msec 5500
--keep-alive-interval-msec 4000
--skip-auto-port-forwarding
--local-addr [fdc2:9f3e:3d11:040c::2]:12001
--public-addr [2a02:a465:21f:1:f7f2:5947:3e84:c7d5]:12001
--log-dir /root/.safe/node/node_dir_1
--root-dir /root/.safe/node/node_dir_1
--hard-coded-contacts ["[2a02:a465:21f:1:f7f2:5947:3e84:c7d5]:12000"]
Error of node #1 (root node is #0)
ERROR 2022-04-01T15:38:36.634678Z [sn/src/bin/sn_node.rs:L300]:
➤ Unfortunately we are unable to establish a connection to your machine
([fdc2:9f3e:3d11:40c::1]:12001)
either through a public IP address, or via IGD on your router.
Please ensure that IGD is enabled on your router -
if it is and you are still unable to add your node to the testnet,
then skip adding a node for this testnet iteration.
You can still use the testnet as a client,
uploading and downloading content, etc. https://forum.autonomi.community/
sudo podman network inspect podman
"name": "podman",
"id": "2f259bab93aaaaa2542ba43ef33eb990d0999ee1b9924b557b7be53c0b7a1bb9",
"driver": "bridge",
"network_interface": "podman0",
"created": "2022-03-16T06:56:37.768948963+01:00",
"subnets": [
"subnet": "fdc2:9f3e:3d11:40c::/64",
"gateway": "fdc2:9f3e:3d11:40c::1"
"ipv6_enabled": true,
"internal": false,
"dns_enabled": false,
"ipam_options": {
"driver": "host-local"
ip addr inside container
bash-5.1# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0@if33: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue state UP qlen 1000
link/ether 6a:9e:99:4c:fb:72 brd ff:ff:ff:ff:ff:ff
inet6 fdc2:9f3e:3d11:40c::2/64 scope global
inet6 fe80::689e:99ff:fe4c:fb72/64 scope link
