So now that we have a gameboy emulator stored forever on the network, it only makes sense to have a ps1 emulator too.
The plan is to add the ability to just enter the address of where the game file lives on Autonomi so it can load it directly from there. Then we will have so many people using Autonomi. All using legal game files of course.
Now we are close to being able to answer the question “Does it run doom?” With yes
Is there a start button the bottom left of the screen? If not could be resize issue so you can just resize screen to see mobile view. Let me know if that works for you.
I’ll post github link tomorrow, still needs to be fixed, don’t have audio working yet among other things. And still need to make it pull roms from the network and load them into the emulator.
Might be easier to start with the gameboy emulator as that only takes in one rom file, while the ps1 emulator takes a .cue file AND a .bin file/s.
Slot at the top behind the screen. Make sure the slot and the cartridge are free of dirt, pennies, peanuts, jam, marmite and other things children have in their pockets or cover everything with.
