- From myetherwallet or any other wallet that supports interaction with smart contracts.
- I don’t think there should be a time limit, those people who prefer holding their OMNI-PDC until the transition to a fully working SAFE Network should be able to do so. The original agreement should stay valid.
- Since there is no time limit any pending claims just stay in the smart contract until they are claimed. If they are never claimed then so be it, we’ll continue without them.
Hi,
Any update on ERC20 transition please
Thanks
We’ll most likely start the transition this week.
@Seneca Hey there! I made a post last week about an idea I had: Universal Block List. It was pointed out to me that Project Decorum is basically implementing everything I envisioned and more. I’m wondering how I can contribute to the project, but I’ve been having a hard time getting in touch with you/finding more info.
In your Devcon talk you said it’s FOSS but I can’t find the code–is it currently closed-source? I’ve got several years of coding experience, maybe I could help by submitting PRs. Also, I have another idea that I think could be implemented as a Decorum community: Guerilla Open Access. The Project Decorum proof of concept seemed to be down when I checked, but is the project in a state where I could tinker on setting up a forum instance?
We’re nearly done, the final smart contract is running on the main chain now and things are looking good with our own test (but real) transactions. We’re currently improving the user instructions, after that we should be good to go. There’s still room for some (performance/speed/uptime) improvements in the processing of burn transactions, but we can still do that after we’ve started.
Great to hear we share those ideas! Apologies for not replying to you sooner, I had seen your PM but got distracted and then forgot. Right now the project is not in a state to run a forum instance or something like that, we hope to get it that state soon, clean it up and publish the code. Right now we’re 100% focused on the ERC20 transition, but when that calms down I’ll definitely get back to you on contributing. We are able and willing to pay for relevant PR’s as well.
Great! I’ll PM you my email address.
We are ready for a soft-launch of the OMNI → ERC20 transition!
With a soft-launch we mean that our smart contract is partially paused for now. The pause means that while the smart contract can be updated with the proper ERC20 PDC balance that you are owed, you cannot transact them just yet. This allows us to monitor if the transition data is properly registered in the smart contract before any transacting/trading starts. If something were to go wrong with the smart contract, we could just start over without any monetary losses. Any previously completed OMNI PDC burns would be fully respected.
If everything looks correct we will soon unpause the contract and make a bigger announcement, including on the official website and twitter account. While you are of course free to wait for that, we would appreciate it if some of you could go through the first three steps of the transition already:
https://project-decorum.github.io/pdc-erc20-transition
If you want to manually double check that your burn address is generated correctly, you can do that on this website: TP's Go Bitcoin Tests
Insert your ETH address (without the 0x prefix) at step 3, click send, and compare the output at step 9 with your burn address. They should be the same. If not, discontinue and sound the alarm!
Thank you!
Hello,
I sent my coin, everything went well!
Thank you!
Thanks! Step 3 should now show you the total amount you are owed. You can also see the “Approvals” here: DecorumToken | Address 0x059d44edd2c15fd0050feb8cc97b3e93e5837506 | Etherscan
Hi, can I keep the coins in Omni till the final launch? Are you trying to have in both format or only on ERC 20?
Both will be accepted at launch, but Omni gives you limited options in terms of wallets and it runs on the Bitcoin blockchain which is more conservative in on-chain scaling than Ethereum, so you may need to pay higher transaction fees at launch. Unless you have a very secure cold storage solution for your OMNI PDC in place, I recommend to switch to ERC20 in combination with a hardware wallet.
Claiming the tokens, in step 4, is paused since yesterday.
When do you expect to restart the contract?
Do you have any estimate of when the contract will be re-started?
Looking forward to shifting coins over to ERC20 when it’s available.
The contract will be unpaused around 15:00 GMT tomorrow (23 May).
The contract has been unpaused.
As I expected, a smooth and easy process. Thanks for a great job. My tokens now happily stored as ERC20’s. ![]()
When PDC will be listed on an exchange please?
Depends on the users on this forum. See initiatives like this: Project Decorum - ERC20 Launch - #9 by wize83
Follow that Google docs link and fill out the form. Getting listed (for free) on exchanges is a matter of community effort, not just asking ‘when?’
I will do it tonight
Thanks
Hi Seneca, I keep trying to call the contract…but it keeps telling me that the same hash was imported?
