Hey guys I was trying to look up MaidSafe rust code base on Openhub.com and every time I typed in MaidSafe it says there hasn’t been a commit since 9 months ago.
I guess I’m looking at the C++ code base but I can’t find a way to select the Rust one?
Can anyone please help?
Thanks!
Maybe I’m doing something wrong, but I put in MaidSafe-routing and keep getting something with no commits since 9 months ago.
IDK. I’m on my phone, maybe I’ll go home and try on my computer
Yes @whiteoutmashups it seems on openhub.com it has not been updated since switch to Rust in March 2015.
MaidSafe Routing is called routing as found on github.
MaidSafe · GitHub
GitHub - maidsafe/sn_routing: Routing - specialised storage DHT
Wow, you’re the man! Thanks a bunch it’s a really cool site and I wanted to see how our code base stacks up against other open source projects like FFox etc IDK
Thank you very much for doing all of that!
Edit: still says nothing for 9 months?
@whiteoutmashups: Check out The SAFE Network Open Source Project on Open Hub!
It combines the code of all the SAFE Network libraries. As you can see there are around 28K lines of code in total!
You are talking about The MaidSafe Open Source Project on Open Hub, but I don’t think it will ever be updated because it refers to the old C++ codebase. So in the future, I think you should use The SAFE Network Open Source Project on Open Hub instead
(it’s the Rust codebase)
Thanks! That’s the rust codebase?
Yes, it’s the Rust codebase
