[Offline] Playground sn v0.53.0, sn_cli v0.44.0
Upload the kitchen sink :joy:
Noooooooooooo but …
Oh.
I’m still deleting directory with “dust” from previous test :smiley:
Up it goes with the rest of the house. Not sure where I’m going to live at this point, but we’ll worry about that later
Tip:
mv ~/.safe junk ; rm -rf junk &
# Then do the remaining OP instructions right away, no need to wait
I knew this hack )
I had some weird problems with my router, but after I rebooted it, it seems to work. I just want to make sure the ERROR below is what I’m supposed to be seeing when standing in line to join a node. Is it?
	 ➤ Network is set to not taking any new joining node, try join later.
 INFO 2022-01-21T17:43:45.999890Z [sn/src/node/routing/api/mod.rs:L154]:
	 ➤ c7f45f.. Bootstrapping a new node.
 INFO 2022-01-21T17:43:46.368753Z [sn/src/node/routing/api/mod.rs:L168]:
	 ➤ c7f45f.. Joining as a new node (PID: 185175) our socket: 82.181.14.6:12000, bootstrapper was: 46.101.5.64:12000, network's genesis key: PublicKey(0c1a..d5cf)
 INFO 2022-01-21T17:43:46.370498Z [sn/src/node/routing/core/bootstrap/join.rs:L508]:
	 ➤ join {network_genesis_key=PublicKey(0c1a..d5cf) target_section_key=PublicKey(0c1a..d5cf) recipients=[Peer { name: c7f45f(11000111).., addr: 46.101.5.64:12000, connection: Some(Connection { id: 93824997979728, remote_address: 46.101.5.64:12000, .. }) }]}
	 ➤ send_join_requests {join_request=JoinRequest { section_key: PublicKey(0c1a..d5cf), resource_proof_response: None, aggregated: None } recipients=[Peer { name: c7f45f(11000111).., addr: 46.101.5.64:12000, connection: Some(Connection { id: 93824997979728, remote_address: 46.101.5.64:12000, .. }) }] section_key=PublicKey(0c1a..d5cf) should_backoff=false}
	 ➤ Sending JoinRequest { section_key: PublicKey(0c1a..d5cf), resource_proof_response: None, aggregated: None } to [Peer { name: c7f45f(11000111).., addr: 46.101.5.64:12000, connection: Some(Connection { id: 93824997979728, remote_address: 46.101.5.64:12000, .. }) }]
 INFO 2022-01-21T17:43:46.447482Z [sn/src/node/routing/core/bootstrap/join.rs:L434]:
	 ➤ Newer JoinResponse::Redirect for us c7f45f(11000111).., SAP SectionAuthorityProvider { prefix: Prefix(1), public_key_set: PublicKeySet { public_key: PublicKey(0817..9de2), threshold: 4 }, elders: {Peer { name: 8628c9(10000110).., addr: 178.128.36.242:12000, connection: None }, Peer { name: 8dba70(10001101).., addr: 206.189.117.109:12000, connection: None }, Peer { name: 93757c(10010011).., addr: 206.189.29.68:12000, connection: None }, Peer { name: b53c1d(10110101).., addr: 206.189.123.174:12000, connection: None }, Peer { name: b5cce4(10110101).., addr: 209.97.134.226:12000, connection: None }, Peer { name: b7d7e4(10110111).., addr: 178.128.168.133:12000, connection: None }, Peer { name: f6d50b(11110110).., addr: 209.97.134.24:12000, connection: None }} } from Peer { name: 0ed757(00001110).., addr: 46.101.5.64:12000, connection: Some(Connection { id: 93824997979728, remote_address: 46.101.5.64:12000, .. }) }
 INFO 2022-01-21T17:43:46.963406Z [sn/src/node/routing/core/bootstrap/join.rs:L508]:
	 ➤ send_join_requests {join_request=JoinRequest { section_key: PublicKey(0817..9de2), resource_proof_response: None, aggregated: None } recipients=[Peer { name: 8628c9(10000110).., addr: 178.128.36.242:12000, connection: None }, Peer { name: 8dba70(10001101).., addr: 206.189.117.109:12000, connection: None }, Peer { name: 93757c(10010011).., addr: 206.189.29.68:12000, connection: None }, Peer { name: b53c1d(10110101).., addr: 206.189.123.174:12000, connection: None }, Peer { name: b5cce4(10110101).., addr: 209.97.134.226:12000, connection: None }, Peer { name: b7d7e4(10110111).., addr: 178.128.168.133:12000, connection: None }, Peer { name: f6d50b(11110110).., addr: 209.97.134.24:12000, connection: None }] section_key=PublicKey(0817..9de2) should_backoff=true}
	 ➤ Sending JoinRequest { section_key: PublicKey(0817..9de2), resource_proof_response: None, aggregated: None } to [Peer { name: 8628c9(10000110).., addr: 178.128.36.242:12000, connection: None }, Peer { name: 8dba70(10001101).., addr: 206.189.117.109:12000, connection: None }, Peer { name: 93757c(10010011).., addr: 206.189.29.68:12000, connection: None }, Peer { name: b53c1d(10110101).., addr: 206.189.123.174:12000, connection: None }, Peer { name: b5cce4(10110101).., addr: 209.97.134.226:12000, connection: None }, Peer { name: b7d7e4(10110111).., addr: 178.128.168.133:12000, connection: None }, Peer { name: f6d50b(11110110).., addr: 209.97.134.24:12000, connection: None }]
 ERROR 2022-01-21T17:43:47.195671Z [sn/src/node/routing/core/bootstrap/join.rs:L174]:
Yep, you’re in the queue, congratulations!
Same error as last time:
d:\SN>safe files put "h:\_Games\Crazy Collection\CC-01.iso"
Error:
   0: ←[91mClientError: Failed to obtain any response←[0m
   1: ←[91mFailed to obtain any response←[0m
   ←[35m/rustc/02072b482a8b5357f7fb5e5637444ae30e423c40\library\core\src\result.
rs←[0m:←[35m1911←[0m
Backtrace omitted.
Things seem to be going pretty well. I guess I’m still standing in line to join. But I also started PUTting a large file, and then I got the Timeout below. Could that be because I’m PUTting over a slow connection at the same time, or is it something else?
sascha@sascha-Librem-15-v3:~$ The network is not accepting nodes right now. Retrying after 3 minutes
Encountered a timeout while trying to join the network. Retrying after 3 minutes.
very nice, upload and download seems to be quite fast.
joining doesn’t seem to work for me though. getting a connection error:
safe node join -yy
Error:
   0: Failed to establish UPnP port forwarding
   1: IO error: search timed out
   2: search timed out
I’ve checked that UPnP is enabled in the router.
With --skip-auto-port-forwarding I just get a timeout (as I’d expect, really)
I am still waiting for my node to connect. Meantime I am uploading as much as I can.
@aatonnomicc cannot join in right now and I cannot find a copy of BegBlagandSteal here to upload.
Can someone please upload that cos its not really a testnet - whether official or not- without that track…
I never did manage to CAT that before, so I haven’t even heard it. Please do upload it! I’m PUTting “the guy with the hair”, but that’s going to take some time over this lousy 10 Mb/s connection.
First indication of possible hasssle… :grimacing:
safe files put -r ~/Music/Beggars_Banquet\ -1968/
FilesContainer created at: "safe://hyryyryyn8j8cyap89gq33e1handu1und7znjbyiynkiysiy6h7wusghptozoeuy?v=hgip1akd6y1eg5cnzxjfqayrb7yyyobuttozu3uwcoggpcnoq1aho"
E  /home/willie/Music/Jamming With Edward/02. It Hurts Me Too.mp3  <Content may have been correctly stored on the network, but verification failed: safe://hygyy1yybt4edssthcyagpq9p3mu48zcxhj4k5h818bx9xw9mypq5f8ymmduo>
Anything to download to test speed?
sascha@sascha-Librem-15-v3:~/Safe_put$ time safe files put Eraserhead.avi
Error:
   0: ClientError: Failed to obtain any response
   1: Failed to obtain any response
   /rustc/02072b482a8b5357f7fb5e5637444ae30e423c40/library/core/src/result.rs:1911
Backtrace omitted.
real	36m28,111s
user	9m49,709s
sys	3m3,370s
Try
“safe://hyryyryynsp1t68capjpsw9uxx698ppa3c7k4h4p3q8acmusw4io1hex7xreyeuy?v=h1nf3epktercttdykzwssd9skwu7dthog96zqfwekdmz9pk685t1y”
for 60MB of vintage Stones*
*Parental Advisory - you thought err err "Star Star was a bit risque?
I have beg blag and steal can I upload it whilst waiting to join as a node?
has anyone tried to build? I am getting…
   Compiling safe_network v0.53.0 (/home/josh/safe_network/sn)
error: there is no argument named `attempts`
   --> sn/src/client/client_api/mod.rs:225:81
225 |             error!("Initial probe msg to network failed. Trying again, attempt: {attempts}");
    = help: if you intended to capture `attempts` from the surrounding scope, add `#![feature(format_args_capture)]` to the crate attributes
error: could not compile `safe_network` due to previous error
Yup [10 characters]
