A new testnet: 50gbRound2
Here we have round two of the 50GB/25-node testnet. You cannot join this network with a node just now. We’re looking to verify the fixes applied since the prior 50GB testnet (mainly that registers cannot be saved indefinitely and that with that, the network should fill all the way up).
Getting involved
As noted above, we’re not looking to check out node joins just now.
As such, it’s only safe client and PUT/GET data that we’ll be checking out. The CLI is limited to files of less than 10MB.
To get involved you can need to have the safe cli installed.
If you already have the safe CLI installed. You should check your safe version by running safe -V, if this does not match the recommended version you should update by following these instructions using 50gbRound2 as the testnet-name, and 0.68.3 as the required safe version.
What’s helpful and reporting issues
Right now, keep uploads small. < 10MB / file.
There is a temporary limit added, and you will get an error if surpassing 10MB. The error is not super informative currently, but you will know by the size that it’s due to surpassing this temporary file size limit.
If you are consistently seeing issues PUTting data or retrieving data you have PUT, please run your command with RUST_LOG=sn_client prefixed to it (on Linux/Mac at least). The output there, and MsgIds that have been sent/failed will be key to debugging.
We’ll try to report back stored data sizes at nodes as we go, so we can see if there’s a correlation between capacity and reliability.
This is what we’re using to verify data-storage just now.
safe://hygoygym7tsj5hhyyykd1aqpw3djxea6om6xku568ahm7hy7gfn6q5gy7xr
safe://hygoygym19bdbzg6jakfzkmacxurpkbuphgsxi6af3aecugfqjfaq66shww
safe://hygoygyq1xiofs8kx11jwkcguzuocd1xa5qp767bjjz39yrh44eo1mjkjch
safe://hygoygypnrqirzo7r5w464mnda8s6sdpatyrco5pda1w8nh5appa3ycb98h
safe://hygoygykajkeropyam6yihj9exdhn5o4b1pbjbeet4bazqo8m47ga3pw8mo
safe://hygoygyp8c1wy7ijrpnesz9cj7enf4ms9oxhmp5m4r4yw4pjcemgywekf9r
safe://hygoygye13iznm1yxzpxp9seh6j8weh84c5ib3fq9mxozz4h6hb95o3uduo
safe://hygoygycc11b4pmrcb97ro6ro3wxh3cfrgi7ctbiwyya8mkktq1j35ysmzh
safe://hygoygykzkguckqygm985f5jrhcw87wiskbc97bottab47tq6fm9zm85f7r
safe://hygoygyewnaj8o7za3qycckfy95o5j9gex6s3b8jygr9j48aiyzthc36ffo
safe://hygoygykime3s7rup1ezeiqeqo1zy1o4bqmckewhriun889c64n4umxcyih
safe://hygoygyc98c1ozh1cn9edxeworctuagt465zyybr61m8judfry4a4zycf8c
safe://hygoygyqcq8bift7urnftiqxzn7d877ckwtk85haawg7oigm3bhn3r1dx7e
safe://hygoygyk7dzmcqxm3q4np87unu6tb9d8qt44fowxgqrhjy1xs6xgt69hade
safe://hygoygymq98z86j1oagpctmg7pnixz94ckekpgytu1jkb45du8xw49qrr4w
safe://hygoygypoq7y31uedr7c6q6e3jaxhd94id3r8bwn7od3f79hgdj7xbqibjr
safe://hygoygykw8iw7wt9o3c7w36hi5xc1coyjdmdfm6dima3y9ehefxipxkwg3w
safe://hygoygyc67ozi6m9i9o8xq5wti7ysa4g6nodxetmdgw64g5pw1qmucheeac
safe://hygoygyqsxzn4p6mjx7ggj98pqc4he53xk1c54kw3hq1967n4yga1nbo3iw
safe://hygoygyxojetcr5553xfyjnfoh3ywge7grs8d7z66e8nf678stecagdkomw
safe://hygoygyqf4au3yf7ouyi7imu1hty5qrsjppy1mj5uba5tahnxkmocys5g7h
safe://hygoygyx41a9samc35ep6h7y6zwku5ess3377f8awtuwn44r1pc5w3ragky
safe://hygoygyej97u6irwmgq1od4s8m6h8epbkgmmwqtghhhy1hbcsntizpjmh3c
safe://hygoygypn9urw4mhoqfabnke71e8usekjeg8m54t1fkoeigdyr5srgsqoia
