Network traffic constantly sits at maximum
I’ve been seeing the following problem for the last few days (mainly because I’m booting new machines, probably the problem is from before).
I used to set a 20 second gap between node startups, but that is no longer enough to download data successfully and node startups overlap.
After booting all the nodes seem to work, but they burn significantly less ram than normal and write no new chunks of data (disk reads and writes are practically 0), but the network traffic constantly sits at maximum:
As far as I can tell from looking at the logs they are shunned and isolated in a small island. Is anyone else experiencing this problem?
It is probably due to this problem that many people complain that they do not win attos in the launchpad. This problem is gone if I start the nods every 3 minutes.
Check out the Dev Forum
there’s something going on I think. I’ve just started 150 nodes at home via antctl and most of them have zero peers. Some are working and receiving chunks but most are sitting at 0.
what are your parameters
ant_networking_live_time
ant_node_uptime
saying?
