Need urgent help
Hello everyone.
I need an urgent help. 1 month ago my crypto accounts got compromised somehow and all my wallets got drained out ( about $150k). Even my omniwallet which is used to store safecoin is compromised and the bitcoin stored there is gone now and they have changed the password so I cant the access the account. Luckily only a little amount of maidsafe and pdc is there.
I am really not sure how to transfer out the maidsafe now from that wallet.
Devs could you please guide me any way. I am super depressed.
if u have maid on paper wallet, you can login to omniwallet, paste there (I think) private key, and then send to another new adress, with new private key, you need some btc as fee.
They changed the password so cant login using the old credentials in omniwallet.
if u have private key, you have access to your coins, try create a new wallet on omni and then paste key
Thanks, that helped. I can access the funds now, but not have any spare btc to transfer the maids.
sounds like your typical bait/scam, you cannot acquire a couple dollars in btc?
I meant I didnt have any spare btc in that wallet. I had to transfer from another wallet which luckily had some.
happy you recovered some funds at least
Yea but kinda lost all of my life’s savings.
i hope those 35K coins will make you recover some life savings at some point :cry:
