Thank you, surely enough I missed the exhaustive guide by @Sotros25
I’ll go about completing the KYC on Altcoinomy now.
Would you like any UI updates?
I could start a few options and send you the code
Great project
Sure why not! I’m bad at UI design haha
3 posts were merged into an existing topic: MaidSafeCoin is now available on the Ethereum blockchain, thanks to eMAID
Uniswap probably changed some of their API things but the eMAID Dashboard is back up online now.
I would also recommend to use this now to view the pool:
https://app.uniswap.org/explore/pools/ethereum/0x35593881b7723b39A5bDbcb421e55C1Ff1953F4B
Overhaul with Autonomi colors and new links. Minor improvements for mobile browsing.
Dashboard can be found here:
Dashboard Server is being migrated since free azure trial has ended. Will be up again this week I think.
you can get 2 forever free vm’s at oracle cloud
I got 1 forever free vm after several attempts to signup. ![]()
Same domain name, nothing has changed. ![]()
API access: https://emaid.online/api
Is conversion from MAID to eMAID still possible? I read a few months back there were some problems … all sorted or no?
Nothing to worry about here at least, its running smoothly.
The alt.co KYC support group telegram channel is quiet but active with nobody screaming and @SwissPrivateBanker and his associates are far too professional to let problems remain unsorted.
We have bigger things to concern us.
I did a conversion for some maids to emaids by alt.co few months ago and there were no problems and support is fast and professional.
