Launchpad and LVM
This might catch someone out.
Im not sure that launchpad is handling LVM drives correctly.
I am pretty sure not many folk are using LVM AND using launchpad so doubtful if its high impact.
Both LVM drives created at the same time. Running as user safe, the binary is in /home/safe.
In Linux everything is a filesystem. It would be nice to just be able to enter the path. I’m also locked out of my biggest partition, because it’s root dir is owned by root, and hence grayed out as unaccessible.
Can you change your biggest partition to root:safe or some other user?
Hmm probably that would be possible, even if only for creating nodes. When node is running, this can be changed back. Thanks for the hack idea!!
