I’m trying to connect a node to a genesis node created on localhost, with the genesis node is running inside a container and the connecting node outside.
I’m having an issue with safe node join.
$ podman ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
f4c9e742c101 ghcr.io/safenetwork-community/rootnode-ipv4:main 12 seconds ago Up 12 seconds ago 0.0.0.0:12000->12000/tcp safe_node
$ safe --version
sn_cli 0.36.0
$ safe node bin-version
safe_network 0.32.0
safe networks add local-ipv4
safe networks switch local-ipv4
safe node join
$ RUST_BACKTRACE=1 safe node join
Joining network with contacts (PublicKey(0969..92cb), {127.0.0.1:12000}) ...
Storing nodes' generated data at /home/folaht/.safe/node/local-node
Error:
0: Error launching node
1: error: Found argument '-v' which wasn't expected, or isn't valid in this context
USAGE:
sn_launch_tool-join [FLAGS] [OPTIONS] --genesis-key <genesis-key>
For more information try --help
1:
/rustc/c8dfcfe046a7680554bf4eb612bad840e7631c4b/library/core/src/convert/mod.rs:540
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ BACKTRACE ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
⋮ 2 frames hidden ⋮
3: safe::operations::node::node_join::he9738ea05d673347
at <unknown source file>:<unknown line>
4: safe::cli::run_with::{{closure}}::h99be10932769df39
5: <core::future::from_generator::GenFuture<T> as core::future::future::Future>::poll::h80cbfc19d38324f1
6: tokio::park::thread::CachedParkThread::block_on::h9409c405307696f3
7: tokio::runtime::thread_pool::ThreadPool::block_on::h4ba6a069e0892e7d
8: tokio::runtime::Runtime::block_on::h8898efea270094fe
9: safe::main::hd88a3586d1ac1e9c
10: std::sys_common::backtrace::__rust_begin_short_backtrace::h3031dbf7d21b11b4
11: std::rt::lang_start::{{closure}}::h8303f569986729bc
12: core::ops::function::impls::<impl core::ops::function::FnOnce<A> for &F>::call_once::h8e37053185df443d
at /rustc/c8dfcfe046a7680554bf4eb612bad840e7631c4b/library/core/src/ops/function.rs:259
13: std::panicking::try::do_call::h28d83eabce0b9ba1
at /rustc/c8dfcfe046a7680554bf4eb612bad840e7631c4b/library/std/src/panicking.rs:401
14: std::panicking::try::habb08b58a5c06b6e
at /rustc/c8dfcfe046a7680554bf4eb612bad840e7631c4b/library/std/src/panicking.rs:365
15: std::panic::catch_unwind::h3cb2485b63db504e
at /rustc/c8dfcfe046a7680554bf4eb612bad840e7631c4b/library/std/src/panic.rs:434
16: std::rt::lang_start_internal::{{closure}}::h9f793569c8817790
at /rustc/c8dfcfe046a7680554bf4eb612bad840e7631c4b/library/std/src/rt.rs:45
17: std::panicking::try::do_call::h50eb9f023e42c1ec
18: std::panicking::try::h8481c5e8b646989c
19: std::panic::catch_unwind::h4d7844a157b7b8e5
20: std::rt::lang_start_internal::heb2c068806062534
21: main<unknown>
Run with COLORBT_SHOW_HIDDEN=1 environment variable to disable frame filtering.
