Having just come across MaidStore and being very excited about its potential, I wanted to spur a discussion about its anonymity properties … particularly since the whistleblower use case is mentioned.
So would Snowden be safe in publishing highly sensitive documents to the network?
When we assume that:
Our adversary can monitor any and all links between peers and can capture encrypted RUDP traffic for analysis.
Controls a proportion of nodes on the network
This is my (probably flawed) understanding of how a document would be published by a whistleblower:
Document is split into a number of chunks and encrypted
a FIND_NODE operation is used to find the most appropriate node for the each chunk
the chunk is saved on the node with the STORE operation
During the FIND_NODE procedure, the whistleblower has revealed his IP address, and the fact that he is looking up a node for a certain ID, to his peers on Hop 1.
These peers can build lists of (IP address, time, ID) to log all IPs involved in lookups for the sensitive document chunks
The first IP address to lookup a relevant ID may not be the whistleblower but may be a few hops away from him
Coupled with our global passive adversary, this is dangerous.
Adversary can perform network analysis, determining which peers were connected to whom during a specified time window.
It could build a shortlist of IPs belong to the whistleblower.
Of course during the STORE procedure, if one of the nodes is malicious they will know to be on the look-out for particular chunks that belong to the sensitive-leaked-document. If the whistleblower tries to STORE to a bad node, then he reveals his IP quite trivially
