not sure how but here is aautonnomicc.json
aautonnomicc.json.zip (212.5 KB)
Imported! I like this Patosh acid ![]()
nice ill upload more now i know its importable @Patosh acid is pretty sweet
I just downloaded it, imported aautonnomicc.json and it worked ![]()
This is the first app that I’ve been able to download and use the Autonomi network without needing to install developer tools and use command line… the network is becoming tangible!
Looking forward to seeing how this develops, and how music discovery etc becomes possible as more stuff is uploaded.
Also great to see Android and iOS versions are planned. The easier it is for people to ‘just use’ Autonomi the better.
Fantastic work team Jams
Amazing work!
Well done and congratulations!
Will Jams have any control over the music that is uploaded and made public?
Opening jams-player on MacOS (Seqouia) stops with a “Apple could not verify is free of malware that may harm your Mac or compromise your privacy.” error. I was able to remove that by doing a
xattr -d com.apple.quarantine jams-desktop.app
I guess this true for all mac apps not signed¬arized via apple
It just does not play the song. The download was successful and I can play the downloaded song from the folder with VLC, but in Jams nothing just happens.
Also, in settings it says that I am not connected to internet, though I am. It says this even after successfully downloading songs.
Anyway, I expect these to be just some minor bugs. Congatulations for releasing this! And thank you for taking it all the way over to here. ![]()
goooooood!!!
We have that issue flagged but thank you for reporting!
The file not playing could possibly be the file type not being supported. We have that flagged as well to expand supported file types, assuming that is your particular issue. Any idea the file type? If it’s mp3 it most definitely should work.
This is exactly right. This is just the beginning and what others are working on now will help us down the line and vice versa. Exciting times.
No sir!
If someday offensive or undesirable content is an issue, I think we probably agree to take a filter approach rather than censorship. We could take some inspiration from web of trust type things or perhaps something like what would be planned for Decorum by @Seneca and @bzee, which is in that same vein.
Hope that clears things up. ![]()
Great to hear.
If the copyright people come complaining do they have a target? I suppose even if they do the music will still remain?
Is there a way for artists to get paid / sell their tracks?
It is mp3, and one that others have reported working:
I opened the app, tried to listen the songs from the list of @aatonnomicc, first without signing in, then signed in. Neither song plays and both of them are downloaded and play with VLC. I’m on Ubuntu 24.04.2 LTS. Logs here.
[LOG] Attempting to check if network is connected
[WARN] IPC custom protocol failed, Tauri will now use the postMessage interface instead {}
[LOG] network is not connected
[LOG] connecting...
[LOG] connecting...
[LOG] Connected event received
[LOG] connected.
[LOG] connected.
[LOG] network is connected
[LOG] getting user...
[LOG] user: null
[LOG] User not found.
[LOG] i18next: languageChanged en
[LOG] i18next::translator: missingKey en translation select_sort_order select_sort_order
[LOG] Download Folder: /home/toivo/Downloads
[LOG] Extension: mp3
[LOG] File Name: Patosh-RoughNight
[LOG] Generated File Path: /home/toivo/Downloads/Patosh-RoughNight.mp3
[LOG] URL: http://localhost:12345/%2Fhome%2Ftoivo%2FDownloads%2FPatosh-RoughNight.mp3
[LOG] File Name: jams
[LOG] Generated File Path: /home/toivo/Downloads/jams.mp3
[LOG] URL: http://localhost:12345/%2Fhome%2Ftoivo%2FDownloads%2Fjams.mp3
[ERROR] balance: {"Common":"Safe: NotLoggedIn"}
[LOG] Signing out user sign out user...
[LOG] logging in...
[LOG] Sign In event received
[LOG] logged in.
[LOG] user: {"username":"Toivo","address":"0x9fecB2d84C2e186429e10b00d72273e2b5Dd4b97"}
Can you check in console (Ctrl + Shift + I), if this is something similar?
I’ve tried to run the Mac version jams-desktop_0.1.6_aarch64.dmg but it fails to open with this error:-
This is the page available in the User Guide from the ‘?’:-
but it isn’t the usual one of the source not being trusted so having to allow the App to be opened in the Security settings because it’s not listed there with a button to ‘Open Anyway’.
So could it be the other possibility mentioned that you got one version signed but then published another?
EDIT
Then I saw @gmax92 's comment above:-
and doing xattr -d com.apple.quarantine jams-desktop.app
has allowed it to be opened!
Thanks for the report. I’m not familiar with macs. @Nigel , did you have similar problems on your Mac?
I think the issue is choosing the arch 64.
Try this one. https://github.com/JAMSplayer/jams-app/releases/download/release-v0.1.6/jams-desktop_0.1.6_x64.dmg
Edit: I see another users comment solved your issue. Great!
It’s so cool to be seeing your icon in my Dock after all these years!
Upload some songs and share your list! ![]()
im planning on having an all things autonomi house party in the Autumn, with a focus on music, got some great guys who sing and guitar well, i’ll encourage them (3 cans for each tune
)to upload at the party once they set up an account.
. I’m going to play around with the app more and will look for content to upload ![]()
