@rusty.spork What was the time and date of the payment? Stupidly I’m using the same address as I’m receiving node payments into so it’s rather hard to find without knowing the amount.
I included the arbscan Txs in my post
9 hrs ago (Aug-14-2025 09:31:03 AM +UTC)
9 hrs ago (Aug-14-2025 09:31:57 AM +UTC)
9 hrs ago (Aug-14-2025 09:34:30 AM +UTC)
I voted for Ryyn, but did not get anything back. I may have made a mistake somewhere though. @rusty.spork is it OK if I DM my transaction details to you? Can you check it out, please?
@rusty.spork I think I’ll have to send my transaction details as well. And a screenshot of the Backing page. All the projects I backed have made it through to the final 12. I’m not on those 3 transactions though. ![]()
Yes, reach out to me via discord
To let othes know, this was most likely my error. I probably sent the tokens directly, not via the voting page. I don’t remember exactly.
I will anyway get my original tokens back after a year, so not that big an issue.
That suggests you are thinking of backing a project where tokens used are returned. Maybe check the backing page and see what you backed there
For voting you only get tokens if the project was voted into the top 12 and according to the votes places.
Can someone pls explain to me how does this work? I have used this website - https://backing.impossible-futures.com/ , connected my wallet, backed some projects and I locked my ANT to buy Pledge points. In the bottom right corner, it tells me “Current Split of Rewards - XY of ANT”. Should I automatically receive this amount to the wallet which I used for buying Pledge points? Because so far, I do not see any coins received but maybe I just do not understand how does it work. If someone can enlighten me, please?
The scheme is complex and confusing - it consisted of two stages. What you describe is the second stage, for which you will receive tokens after 1 year. The transactions announced in this topic are for the first stage, in which we voted on which programs would go to the second stage…
Hopefully, the conclusions have been drawn and we won’t see such confusing schemes in the future.
oh yes, the first round was the “gamble” round, where we could lose our tokens if the project did not make it to the top 12? Do I recall correctly?
You remembered correctly. The interesting thing is that out of all the complexity, even the team got confused and sent by mistake money to the first canceled “gamble” round participants…
Since Colony was technically 13th, but then moved to 12th, did those users get their pay out? Or not because it was 13th?
Likely so.
I know I put my money on Ryyn, and I did it on may 26th. According to this page it must be backing then, because of the deadlines: Impossible Futures
But then again, I’m not 100% sure what deadlines were shifted and when, and if all those shifts are correctly updated to various places.
Just go to the backing page https://backing.impossible-futures.com/ and to the voting page https://voting.impossible-futures.com/ and connect your wallet on each page and see what you backed and what you voted.
That will help you remember which you did and confirm it either way
Just to regain my dignity
I did write the seed down after all ![]()
You must have hid it well, took you 2 weeks to find it ![]()
