I made a script to launch a testnet with multiple nodes from one linux machine! you could launch from multiple machines also nut read on!
how to use:
tested in debian 10/11 and manjaro
a. debian: sudo apt-get update && apt-get install -y git or if you dont have sudo from root run first apt install sudo
b. manjaro sudo pacman -Syy && sudo pacman -S --noconfirm git
close and open your terminal ( or exec bash for example)
then clone the git repo
git clone https://github.com/dreamerchris/dream_sn_node_joiner.git
then cd into the new folder
cd dream_sn_node_joiner
here you can launch the dependency scripts for manjaro or debian:
sh dep_installer_debian.sh or sh dep_installer_manjaro.sh
now to launch the testnet in one machine
first see the script and edit it according to your needs:
nano launch_n_multi_joiner.sh
here is the file:
#!/bin/bash
NODE_NUM=35
USER=$(whoami)
ACTIVE_IF=$( ( cd /sys/class/net || exit; echo *)|awk '{print $1;}')
LOCAL_IP=$(echo $(ifdata -pa "$ACTIVE_IF"))
PUBLIC_IP=$(echo $(curl -s ifconfig.me))
SAFE_PORT=12000
mkdir -p $HOME/.safe/node/local_node0/
CURRENT_ROOT_DIR=$HOME/.safe/node/local_node0/
CURRENT_LOG_DIR=$HOME/.safe/node/local_node0/
CURRENT_NODE=0
echo -n "#!/bin/bash
RUST_LOG=safe_network=trace,qp2p=info \
$HOME/.safe/node/sn_node --first \
--local-addr '$LOCAL_IP':$SAFE_PORT \
--public-addr '$PUBLIC_IP':$SAFE_PORT \
--skip-auto-port-forwarding \
--root-dir '$CURRENT_ROOT_DIR' \
--log-dir '$CURRENT_LOG_DIR' & disown" \
| tee $HOME/.safe/node/start-node$CURRENT_NODE.sh
chmod u+x $HOME/.safe/node/start-node$CURRENT_NODE.sh
echo -n "[Unit]
Description=Safe Local Node $CURRENT_NODE
[Service]
User=$USER
ExecStart=$HOME/.safe/node/start-node$CURRENT_NODE.sh
Type=forking
[Install]
WantedBy=multi-user.target"\
| sudo tee /etc/systemd/system/sn_node$CURRENT_NODE.service
sudo systemctl start sn_node$CURRENT_NODE.service
sleep 3
safe networks add mynet
safe networks switch mynet
for CURRENT_NODE in $(seq $NODE_NUM)
do
SAFE_PORT=$((12000+$CURRENT_NODE))
CURRENT_ROOT_DIR=$HOME/.safe/node/local_node$CURRENT_NODE/
CURRENT_LOG_DIR=$HOME/.safe/node/local_node$CURRENT_NODE/
mkdir $CURRENT_ROOT_DIR
$HOME/.safe/node/sn_node \
echo -n "[Unit]
[Service]
User=$USER
Type=forking
[Install]
sleep 3
done
echo ""
echo "End of multi sn node joiner script. Starting vdash!"
echo ""
$HOME/.cargo/bin/vdash $HOME/.safe/node/local_node*/sn_node.log
here you can edit the NODE_NUM which is the number of nodes to start! (make sure you have enough space in disk as the recent removal of max-capacity option has defaulted to 10gb per node)
also you can edit the SAFE_PORT which is the starting port (of the genesis node) please keep this ending in 00 as the other nodes are going to be ending to 01-35 (12001-12035)
you are good to go!
run sh launch_n_multi_joiner.sh
now your new config for your network is in ~/.safe/node/ and its called node_connection_info.config!
so if you want others to join you need to either send then this file or make it available in a static url (I use nextcloud)
and either they should use safe networks add mynet pathToTheConfig.config
or
safe networks add mynet urlToConfigDownload
dont forget to use safe networks switch mynet
and then either use
safe node join --public-addr x.x.x.x:xport --local-addr x.x.x.x:xport --skip-auto-port-forwarding
or you could also use my multi_sn_node_joiner.sh as described in this thread:
