I’d like to understand the new data types listed here in main but when running cargo doc they don’t appear in the generated docs. So:
- how do I generate docs which include
pointer and graph?
- what is the status of those types when run with a local network at
main?
cc @loziniak any tips?
These are in main tidied up now from yesterday. Docs are being refactored and should have been valuable today AFAIK (cc @JimCollinson ) so any time now, but should be in cargo docs now at least in main. They are defined in the ant-protocol crate if that helps
@Anselme is about to refactor the cli to use these and test them for usability as well.
I’m still using stable branch. And most of the time code tells me more than docs, so I often click “source” in docs.rs .
Have you been able to use Pointer or GraphEntry? Any issues?
I used Transaction (renamed to Graph in main) and Scratchpad, works ok on local testnet.
