Fleming Testnet v3 Release - * NOW OFFLINE - v4 RELEASED*
My first node connected! :open_mouth:
I can see blobs being stored and everything! :sunglasses:
In previous NAT tests last year, I couldn’t connect a node, so it looks like this latest version likes my router.
yes, I pinged it. 87 to 89 ms times.
I’ve got 23 megabytes of chunks :grinning:
Did someone create safe://lazydog before me? I tried to create it and it said it already existed! :slight_smile:
I can dog it, but it is taking a while to cat. I’m excited to see what it is now! :rofl:
All, if you post an error please state the OS you are using.
auth restart does stop and starts it even if it couldn’t stop it
UBUNTU 18.04.4.LTS
safe cat safe://hygoygyenxp3e516x1uktohmzxd3w8ubcnr9rhcd97xrjfsf4pztn5gbynw > Toivo_through_bottle.jpg
Error: NetDataError: Failed to GET Public Blob: SelfEncryption(Storage)
as wrong as it sounds…love the feeling of chunks coming through!
[sn_node] INFO 2021-04-15T22:31:05.821653+10:00 [src/node/handle.rs:27] Handling NodeDuty: WriteChunk
[sn_node] INFO 2021-04-15T22:31:05.821752+10:00 [src/chunks/chunk_storage.rs:65] TRYING TO STORE BLOB
[sn_node] INFO 2021-04-15T22:31:05.821821+10:00 [src/chunk_store/mod.rs:100] Writing chunk
[sn_node] INFO 2021-04-15T22:31:05.825181+10:00 [src/chunk_store/mod.rs:104] consumed space: 1048604
[sn_node] INFO 2021-04-15T22:31:05.825245+10:00 [src/chunk_store/mod.rs:105] max : 2147483648
[sn_node] INFO 2021-04-15T22:31:05.825300+10:00 [src/chunk_store/mod.rs:106] use space total : 4194416
[sn_node] INFO 2021-04-15T22:31:05.845263+10:00 [src/chunk_store/mod.rs:125] Writing chunk succeeded!
[sn_node] INFO 2021-04-15T22:31:05.849660+10:00 [src/node/handle.rs:27] Handling NodeDuty: No op.
[sn_node] INFO 2021-04-15T22:31:24.551889+10:00 [src/event_mapping/mod.rs:44] Handling RoutingEvent: MessageReceived { content: “000500…”, src: Section(2f9253…), dst: Node(2c1d4b…) }
[sn_node] INFO 2021-04-15T22:31:24.578632+10:00 [src/node/handle.rs:27] Handling NodeDuty: WriteChunk
[sn_node] INFO 2021-04-15T22:31:24.578760+10:00 [src/chunks/chunk_storage.rs:65] TRYING TO STORE BLOB
[sn_node] INFO 2021-04-15T22:31:24.578901+10:00 [src/chunk_store/mod.rs:100] Writing chunk
[sn_node] INFO 2021-04-15T22:31:24.581849+10:00 [src/chunk_store/mod.rs:104] consumed space: 1048604
[sn_node] INFO 2021-04-15T22:31:24.581886+10:00 [src/chunk_store/mod.rs:105] max : 2147483648
[sn_node] INFO 2021-04-15T22:31:24.581917+10:00 [src/chunk_store/mod.rs:106] use space total : 5243020
[sn_node] INFO 2021-04-15T22:31:24.608169+10:00 [src/chunk_store/mod.rs:125] Writing chunk succeeded!
[sn_node] INFO 2021-04-15T22:31:24.612002+10:00 [src/node/handle.rs:27] Handling NodeDuty: No op.
auth create --test-coins gives me
AuthdClientError: [Error] ClientError - Response not received: read error: connection closed: timed out
EDIT: If there is nothing in my sn_node log I am accepted as a node?
On both laptop and desktop machines I get a similar error trying to start sn_authd
I have stopped all safe and sn_authd process and nuked the .safe folder
willie@gagarin:~$ safe auth start
Error: Failed to start authd
Caused by:
    AuthdError: Failed when invoking sn_authd executable from '/home/willie/.safe/authd/sn_authd'
willie@gagarin:~$ /home/willie/.safe/authd/sn_authd
sn_authd 0.5.2
SAFE Authenticator daemon subcommands
USAGE:
    sn_authd <SUBCOMMAND>
FLAGS:
    -h, --help       Prints help information
    -V, --version    Prints version information
SUBCOMMANDS:
    help       Prints this message or the help of the given subcommand(s)
    restart    Restart a running sn_authd
    start      Start the sn_authd daemon
    stop       Stop a running sn_authd
    update     Update the application to the latest available version
willie@gagarin:~$ /home/willie/.safe/authd/sn_authd start
Starting SAFE Authenticator daemon (sn_authd)...
[Error] GeneralError - Failed to start sn_authd daemon '/home/willie/.safe/authd/sn_authd' (exit code: 1)
What trivial mistake am I making?
Ubuntu 20.04 and 16Gb RAM on both machines
I get the same error if I try to get that file.
Are auth and authd the same? Both exist? Just guessing…
Well that was too easy!
Just for fun and to make it more difficult, I’m running it all through Tor :wink: lol … amazingly it’s working !!
Edit: It’s probably the mission impossible (network) music running in the background.
You have to add and switch network first.
I was able to get it
Ah OK I was just following the instructions in the OP
I’ll try that TYVM :slight_smile:
And it works – thank you @Traktion
We need to get the OP changed then and move safe auth start to after the networks section
I read it too rapidly and I understood it as your lazydog was a cat!
I’m the worst sometimes. What command do I use to watch my logs?? Trying to start a node before I go off to work. @StephenC that might be a good command to have in the user guide for noobs if there’s room for it.
He’s right here next to me… he looks deeply offended! :rofl:
I am still not able to get it. Weird. UBUNTU 18.04.4. LTS
safe cat safe://hygoygyenxp3e516x1uktohmzxd3w8ubcnr9rhcd97xrjfsf4pztn5gbynw > pullopollo
Some context:
  1. I am putting it again at the same time. But I was not able to get this file even before.
  2. I have another cat process running in another terminal
Question: are the cat processes in my system activity monitor these cat’s of Safe? There is two of them running now.
Now I have to go. I’ll be back after a couple of hours.
