We should start the sn_authd process before querying it ![]()
safe auth start should do it.
In under a week, gone through two testnet iterations … Maidsafe is the SpaceX of the new Internet! ![]()
This solved the problem! ![]()
I was just following the instructions in the order they were laid out, and thus tried to restart auth before it was even started. Maybe restart could also just start auth?
Yup, we just had that discussion in the team
Upcoming soon!
Like in 10 seconds maybe? ![]()
I mean I’m really impressed about the pace. But hey, I was quick to report too, wasn’t I? ![]()
OP updated ![]()
in-house we call these T1 T2 etc. today’s was T3 obviously, reminds me of terminator movies
I’ll be back ![]()
Look like bug with handling spaces in username:
Ha! I was just blogging about test net 1 and 2… then test net 3 comes along! ![]()
Ok, blog on hold… testing this baby out! ![]()
Quick note - the network needs to be added/switched before safe auth can start.
$ safe auth start
Error: Failed to start authd
Caused by:
AuthdError: Failed when invoking sn_authd executable from '/home/paul/.safe/authd/sn_authd'
Ah of course - OP re-updated!
Chunks… I got them… they are immutable. ![]()
I want your chunks, your boots and your motorcycle. I got them first time. No loops needed here.
Running into errors almost every step of the way…
think@thinkpenguin:~ safe -V
sn_cli 0.23.2
think@thinkpenguin:~ safe auth install
Error: Failed to find a release available to install
Caused by:
0: ReqwestError: error sending request for url (https://sn-api.s3.eu-west-2.amazonaws.com/?list-type=2&max-keys=100&prefix=sn_authd): error trying to connect: dns error: failed to lookup address information: Try again
1: error sending request for url (https://sn-api.s3.eu-west-2.amazonaws.com/?list-type=2&max-keys=100&prefix=sn_authd): error trying to connect: dns error: failed to lookup address information: Try again
2: error trying to connect: dns error: failed to lookup address information: Try again
3: dns error: failed to lookup address information: Try again
4: failed to lookup address information: Try again
Can you ping sn-api.s3.eu-west-2.amazonaws.com ?
Node joined for the first time, exciting!
You guys rock
I’ve got a node up and running and that seems to be working.
safe cat was working, but now it’s suddenly not anymore. Getting an error
safe cat safe://hyryyry4aage8oh3dsaw9s5ihio3pmu63qxqduz35g3cpjd46ewuursbecenra
Error: Failed to connect: ConnectionError: Failed to connect to the SAFE Network: QuicP2p(UnresolvedPublicIp)
edit: now I’m getting another error message:
Error: NetDataError: Failed to get current version: NetDataError: Failed to retrieve last entry from Sequence data: ErrorMessage(NoSuchData)
