So, I finally had the time to start the translation of the SystemDocs to german and I’ve come across a couple of things that need clarification. I’m almost finished with chapter 2, but I’d like to start the feedback/clarification process already.
1.2 Do we need to have apps and programs? I stuck with programs because they’re the same thing to me. I guess you’re referring to programs for android/iOS when you’re saying apps?
1.2 “Document processing of any data provided by any program” I have no idea what that means.
1.3 should be called the SAFE client, not the maidsafe client. We should provide a consistent nomenclature so we don’t confuse the users
1.3 “cross-plattform” → extend with (Windows, Linux, Mac), otherwise they might not know what cross plattform means.
1.5 “As there can be multiple Transaction managers coordinating different safecoin transactions at the same time, an unrestricted number of transactions can take place at network speed.” <— what does that mean?
2.2 resilience → meaning redundancy, toughness or resistance? I guess resistance?!
2.2.2 “The real key pair is created and the public key is signed by the revocation private key and this packet (public key plus signature) is stored on the network as a Vault Identification key type. This Hash is then used as the Vault identity.” <---- Which hash? the hash of the “packet”?
2.2.6 “Users do not require to have their account managed, even in a secured manner.” <— No idea what that means.
2.2.6 “As the SAFE Network creates safecoins, users may use these to purchase network resources in an anonymous manner. This uses an exchange or purchasing mechanism.” This needs a lot more explanation for a new user to be understood. I had to read it several times to guess the meaning.
These are my questions so far, I’ll add more as a work my way through the document.
PS: Quite a lot of things are explained more than once in different chapters while others are not explained in enough detail and are hard to grasp for a normal user. A good example is the router stuff. I think most of the normal users won’t understand the use case of a STUN server but would understand the sentence: You don’t need to setup port forwarding on your router. It is a weird mixture of over simplification with a lot technical details. I think there should be two documents; one for the normal user and one for the geeks and nerds out there.
