Feasibility of small setups in the real network
non nanos, no user node operator ‘organic’ uploads, that is the ‘network test user growth resistance’ we are up against. It’s in theory easy to limit gamification by asking at sign up do you want to report logs, if answer-yes, here are a few nanos to test uploads, just do a ‘check if your human’ screen as part of it?
We do all that currently, apart from “here are a few nanos for uploads”
But we’ll be getting to organic uploads in due course.
But I would add the ‘check if your human’ screen gets harder the more nanos you give away, that’s why it’s best to have the nodes earnings cover that, in large part anyway.
this is true.
You should still slip @happybeing a couple of thousand tokens by some mechanism so a truly important part of the whole project is not delayed unnecessarily.
I’ll be fine when they fix the bug with uploading a directory. That was the real killer. Very strange behaviour.
Replicated with safe files upload -p <DIRECTORY>
