Thinking āmockā was some kind of mock, I went into ānot mockā found the exe and ran it. Javascript error appeared.
Curiosity got the better of me and I went into the mock folder, double clicked that exe and the Safe Browser fired up! Tried someā¦ urlāsā¦ like safe://tetris/ and safe://jamz.demo3/ and nothingā¦ just an endless loading indication.
I canāt help with the JavaScript error, but mock is āmock routingā so itās pulling stuff off āfake vaultsā on your computer. None of the testnet stuff will show up using that. Itās mostly for development.
Ok thanks for that. At least I can rule out the mock version.
I know nothing about JS as well however Iām guessing the error is saying it canāt make a folder that it needs to make. This may be because I installed into C:\Program Files which needs Administrator permissions to do stuff inside. Iām guessing though.
I reinstalled as @bzee suggested and the Safe browser fires up.
I try to sign in and Iām told my account doesnāt exist!
Maybe I need to move the folders rather than reinstall them. Problem is that when I tried to move them, halfway through the cut/paste process I was told āsomethingā was accessing a folder and so the process couldnāt complete. So I decided to reinstall from scratch.
ahā¦ Iām an idiot! I created my account using the mock version as so my account doesnāt exist.
Restarted and freed up the folder issue, moved the ānot mockā folder into a user directory, created a new account (using same details as before) and everything works. I have had a game of Tetris
Itās not unusual to chose C:\Program Files to install programs into though and it would be good if the difference between mock and not mock was more explicit.
You are not, you are an early adopter, and thatās a totally different level. Iām happy you get it working, things will become easier and easier as we all want that here, but this process needs people like you to help us out.
