And the 2016 award for Mr Smarty Pants goes to…
What do you mean by saying there is no POW?
Yes I think all accepted and also active, perhaps these can be shown as two groups as exist in the rfc repo, mind you a link to the repo may be enough I suppose. It’s just many folk don’t want to search for docs. I suppose we could link to a google search for all citations and papers, but not sure how far this should go. It does seem an issue, I suppose we need to decide how far we go in supplying all the links and papers. I say this as github links for accepted will change when an RFC goes active. Maybe for ease just a link to active RFC’s and one link for accepted rfc’s root dirs ?
“Nakamoto Byzantine General Problem” is the extension of Lamport’s Byzantine General problem for an open network (this means without a fixed number of “generals”) which is obviously harder to solve and for which I am not aware of a complete solution without PoW.
I do not understand what you mean by “without network effect bitcoin does not solve the problem”. Do you mean that a minimal critical computation power is necessary to achieve security?
Anyway what would be relevant are the mathematical ground for your new approach, this is why I am curious about the magic numbers you give for the size of the groups. In particular how the security improves with larger groups (at which rate?).
There was a load of tests and results, I think posted here for this. If you grab the address_space_tool from our archive in the common library you can run the simulations. There is also a statistical formula which agrees with the simulations, not a proof though. Here it is.
[Edit - sorry about scale, please message for lyx copy if desired]
We also ran a load of tests with “Eureka” (the digital scientist, math tool) to try and calculate a more formal proof, but to no avail, it could not do it, even after running and a large machine for 5 weeks. The closest it got was
x = 6577.35444491108/(2.884820904 + G + 13M) + 1500.62923471823G/(3.029780114 + G - 0.9398090401*M) - 1540.9094305201
With x as attack size, G == GROUP_SIZE and M == Majority. I have the simulation results in csv for anyone who wants the,
So the address space tool gives over 70% attack resistance at Group size > 19 (well quorum actually) and the difference between GROUP_SIZE And QUORUM is the number of nodes out of sync during the lifetime of a churn event. So take QUORUM_SIZE as a security parameter and GROUP_SIZE as the number above quorum to maintain integrity. Testing is easiest otherwise you need to calculate a wide range of parameters (cpu usage for encryption, wire format of messages, number of messages etc.). Some of this we are testing through the MVP roll out to tailor for efficiency.
Hope that helps a bit
Yes I have not heard this description previously. I do know that with a small network and small hash rate then this is not secured. With network effect then it becomes secured with the aid of economic incentive. This was seen from the many clones that were “out hashed” and died. I digress though. Thanks for the description, that helps.
Again why do you say there is no PoW in Maidsafe?
PoW in Maidsafe is called PoR(proof of resource) and is measured by the amount of storage (and by proxy bandwith) that nodes provide to the network.
Because the safe network is not in an open and hackable internet it has it’s advantages over Bitcoin, and one of them is that it can forego the use of blockchain and ASIC mining as it’s security mechanism.
Bitcoin can work over different networks (including Tor), but more importantly that is completely unrelated to the PoW/PoR debate, why is this even being mentioned here?
It is “intends to forego”, not “can forego”. SAFE isn’t available while Bitcoin has withstood years of scrutiny. Pay a bit of attention to these meaningful differences.
It wouldn’t mean that SAFE cannot work securely, but it would mean that you understand the difference between “in testing” and “generally available”, which automatically means any comparison between the two has no real life importance.
It’s being mentioned here because my reply is answering why PoR is possible in SAFE and doesn’t need to use PoW. If SAFE network wasn’t secure then there is no chance of PoR working…
seriously?
What you think anybody reading my post is going to conclude that SAFE network is already built and running because I used can instead of intends?
I’m pretty sure that everyone is well aware of the stage SAFE is in right now and I certainly won’t preface every post I make with “If the SAFE network works as planned” - because that is just common sense by now
PoR in SAFE is used to reward farmers for storing and delivering data, not for security. It’s wrong to equate it with PoW, which is a reward for security work that prevents double spends. I think those are very different things and therefore have different names.
You overestimate the level of technical understanding among general readership, and while they won’t conclude the SAFE is up and running (although they do ask, recently almost once per day, just check out the newbies category if you aren’t aware of what’s going on on this forum) they may conclude that PoW equals PoR and that it’s been “proven” that it’s just as safe. It may turn out to be, but it hasn’t been proven in theory or practice.
If SAFE network isn’t secure the PoR doesn’t work.
If SAFE network isn’t secure then anybody that can hack the network can change the amount of safecoins that any node (or wallet) has and therefore security is essential for Safecoin to work.
That is what Bitcoin uses mining for - security! if SAFE network has security as a baked in feature it doesn’t need blockchain.
That is why I specifically mentioned that SAFE network is not in an open and unsecured internet protocol.
or should I say intends to…
There is a lot of altcoins without POW model but all those have a blockchain so the key here is not POW vs POS, the key is the consensus mechanism.
I’m so absolutely repulsed at the anti-innovative attitude that went on in that thread I WENT AHEAD AND SOLD ALL MY ETHEREUM.
