Connectivity problems to Safe Network
Hi guys,
i can’t connect to Safe Network cause it gives me an error.
I don’t know if you have the same issue. How to solve this problem?
A common cause is not having properly set an invite on invite.maidsafe.net , or having changed IP adress since you set the invite. In this case you just need to update your IP by visiting again invite.maidsafe.net
