think I have successfully uploaded an mp3
this tune is dedicated to @Southside
safe cat safe://hygyy1yybp9edeorgb1wyu9yyoofd9nuz3czc9339kx7gdcumq9fx8r6sj9ey > BegBlagandSteal.mp3
What’s the command to upload a folder full of files @anon26713768?
I’m dealing with bed times with a 3 year old so have limited computer time!!
And wife just gave me those test net eyes that says you aren’t allowed to stay up all night ![]()
safe files put -r my_folder/
I suppose I better try to download that mp3 then…
I liked it good song ![]()
Was a friend of mine recorded it makes me think of @Southside ill wait for the big man’s opinion if he likes it or not then
Dont tell me - someone gave your pal a bass for his 12th birthday and he never grew out of it -amiwright?
Aye, no bad at all.
So… what is the exact command you used to join the community network and then be able to upload that?
just as in @anon26713768 OP except I had an error referring to some .json config file so I deleted said file and started again and every thing worked fist time
then from inside the mp3 folder
safe files put BegBlagandSteal.mp3
nice beat!
20char char
Nah - I just get a timeout
willie@leonov:~/projects/punctureguard/aws$ safe --version
sn_cli 0.38.0
willie@leonov:~/projects/punctureguard/aws$ safe node bin-version
safe_network 0.39.0
willie@leonov:~/projects/punctureguard/aws$ safe networks check
Checking current setup network connection information...
'community-test' network matched!
Current set network connection information at '/home/willie/.safe/node/node_connection_info.config' matches 'community-test' network as per current config
| Networks | | |
| Current | Network name | Connection info |
| * | community-test | https://jc-com-net.s3.eu-west-2.amazonaws.com/node_connection_info.config |
willie@leonov:~/projects/punctureguard/aws$ RUST_LOG=safe_network=info,qp2p=info ~/.safe/node/sn_node --skip-igd
Starting logging to stdout
INFO 2021-11-13T21:07:35.109118Z [sn/src/routing/routing_api/mod.rs:L152]:
➤ 7a3b22.. Bootstrapping a new node.
INFO 2021-11-13T21:07:35.229167Z [sn/src/routing/routing_api/mod.rs:L166]:
➤ 7a3b22.. Joining as a new node (PID: 233651) our socket: 9n.nnn.nnn.nn5:58674, bootstrapper was: 46.101.10.216:12000, network's genesis key: PublicKey(1309..e59e)
INFO 2021-11-13T21:07:35.229701Z [sn/src/routing/core/bootstrap/join.rs:L359]:
➤ join {network_genesis_key=PublicKey(1309..e59e) recipients=[Peer { name: 7a3b22(01111010).., addr: 46.101.10.216:12000 }]}
➤ send_join_requests {join_request=JoinRequest { section_key: PublicKey(1309..e59e), resource_proof_response: None } recipients=[Peer { name: 7a3b22(01111010).., addr: 46.101.10.216:12000 }] section_key=PublicKey(1309..e59e) should_backoff=false}
➤ Sending JoinRequest { section_key: PublicKey(1309..e59e), resource_proof_response: None } to [Peer { name: 7a3b22(01111010).., addr: 46.101.10.216:12000 }]
Encountered a timeout while trying to join the network. Retrying after 3 minutes.
you dont need to join to use the network
I know but I want to put files as well as get them.
You can’t put?
I know we aint hammering it yet but this net looks like the most stable iv used
I can put without joining
I was thinking the same without wanting to jinx it by vocalizing.
Somewhere in my brain is the entirely wrong idea that you had to join to put…
Let me try a put then…
@SmoothOperatorGR It would seem you are not wrong… and I was ![]()
“safe://hyryyryynbfq4ky3pyzzwoitrych57twhx1djcrs3aa46nno3z5taxapeyb4oeuy?v=h5jecngi1j5zdcdkcsy3y7nh3fsoeexqugzmgwenuuwbqfz5w7qty”
have a cat at that then…
cats photos for all!
$ safe files put -r cats/
FilesContainer created at: “safe://hyryyryyn69bwg6ra175iantq6rboxsuyz5g8efc7m5kcubefougdx4ixc4roeuy?v=hd3pdmz65wrsnwk7k51oaucdiqne6bxu3rmx15wp36j1fdkiefajo”
bonus edit: is there a way to download a folder (filescontainer) or do you have to manually download every and each of the files in it?
cat should be for commands not content…
I like pussy as much as the next guy but there are limits…
what extention to use?
edit: scratch that it is stuck on get
