Building on Fedora x86_64 - Rust
People,
I do intermittent builds from scratch and the number of errors continues to decrease - good work!
What I am confused about is: - I thought there was a big change from C++ to Rust but I am still doing basically the same things in my README file as I was doing prior to the Rust developments - when will I need to start building stuff that has Rust code?
Thanks,
Phil.
See the rust libs here dirvine (dirvine) / Repositories · GitHub
I think this may happen sometime in the next couple of weeks. I suggest waiting as I think once the maidsafe repository is switched to rust building with Rust will get easier (not that it is hard).
