Hi,
I’ve asked this question in another sub but haven’t got a clear answer yet and maybe there is no answer to it yet but I might just as well ask it here.
Will ARM devices or similar low powered CPU’s be fast enough to run the maidsafe stack (e.g. Vault software)?
The problem is that encryption routines put a heavy strain on the CPU and therefor often limit the amount of bandwidth or other operations.
Example; I have an Intel Atom powered x86 NAS at home and a usenet download program installed on it.
I have a 100Mbit line but I wont get more than 50Mbit out of it because of the SSL encryption I have enabled on the connection. If I switch off SSL, I get the full 100Mbit.
I think that ARM or Atom devices will have similar problems running maidsafe. I am asking this because I am consider to build me a low powered devices with an ARM CPU and put a fair amount of disks in it.
I hope someone did some tests already or can shed some light on this.
Much appreciated.
Gr,
Lawk
